Clutch adjustment, scrapes noises
Recently we repair the transmission put new Syncros, because when I change gears make a scrap noise. Now works fine changing gears fast, but the clutch pedal was set very low for me , now we set the clutch more high (Up) and now when I change from 1st to 2nd gear fast e a scrapes noise. any recommendations in addition to get the clutch pedal very low again.
Old 11-24-2012, 06:14 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Do you mean it grinds?
In any case you need to adjust the cable. The the pedal will rise to where it is supposed to be.
'85 Carrera Targa
PCA/POC
Old 11-24-2012, 06:33 PM
yes it grinds the I change from1st to 2nd. the pedal now is high, I can leave the pedan in the same position and adjust only the cable to eliminate the grind noise?
Old 11-24-2012, 06:53 PM
DRACO A5OG's Avatar
Well, when you placed the cable, did you make sure to check the clutch arm gap (1.20 to 1.00mm) then the difference of cable pedal pressed and release 25.00mm?
When does the clutch engage on the pedal travel?
'85 Carrera Targa
PCA/POC
Old 11-24-2012, 07:00 PM
