liskeard's Avatar
What is this Hose called?
I'd like to replace this hose on my 911, but for the life of me can't find it listed in the PP cataloge. I've seen some with a much sharper looking hose, than the stock.
Thanks in advance...
Ted
1980 911-SC Targa
Old 06-18-2002, 12:28 PM
Formerly bb80sc
Vipergrün's Avatar
Ted, that's the right-side heater hose.
It can be found at;
http://www.pelicanparts.com/catalog/shopcart/911M/por_911M_exhaus_main.htm
Don't know about hoses other than stock. Make sure they can stand up to the heat
cheers
-Brad
80SC
Old 06-18-2002, 12:58 PM
Hilbilly Deluxe
emcon5's Avatar
And they are different depending on if your car has A/C. Make sure you order the correct one.
Tom
82 911SC Coupe
GTI Cup #43
Old 06-18-2002, 01:00 PM
liskeard's Avatar
Mine has AC, and I'm still not converting the parts diagram to the actual picture, but I'll look again when I get home this weekend.
As for the after-market kind, I've seen one on this board that was stainless steel looking, without the cloth covering. I'll keep looking for that picture.
ted
1980 911-SC Targa
Old 06-18-2002, 01:28 PM
Senior Member
Old 06-19-2002, 06:05 AM
Sean Hamilton's Avatar
Thumbs up See the "Absolute Beginners" diagram.
Ted,
on mine (1980 SC with A/C) I have the part # 22, with the adaptor fittings - #21.
I assume the smaller tube diam' is so that it can feed thru and under the A/C compressor.
Cheers, Sean.
94 911 Carrera 2 993 Cab
http://www.pelicanparts.com/gallery/Sean_Hamilton
Old 06-19-2002, 09:45 AM
