cam shaft seal
hey. im having a little trouble pulling my old camshaft seal out to replace with new one. the cars a 73 911e. its the pulley that belt drives the mfi pump. im not sure what to do. this is probably a dumb question, but could i just put the new seal over the old one? i no thats a dumb thing to do. how does others pull the seals out. i tried small screwdriver.
Old 11-24-2012, 04:02 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Seal puller from hf
Are you talking about rear or front seal?
If rear, you can use a bfs but take care not to mar the housing or it will develop a leak.
'85 Carrera Targa
PCA/POC
Old 11-24-2012, 06:52 PM
its the rear, on drivers side pulley, the one that drives the mfi pump. whats bfs??
Old 11-24-2012, 06:57 PM
DRACO A5OG's Avatar
Big Fing Screwdriver
Can you post a pic?
'85 Carrera Targa
PCA/POC
Old 11-24-2012, 07:02 PM
heres a few pics. im trying to avoid taking off the drivers side heat exchangers.
Old 11-24-2012, 07:14 PM
DRACO A5OG's Avatar
Oh okay, use the seal puller but be very careful on the engine as not to mar the inside.
'85 Carrera Targa
PCA/POC
Old 11-24-2012, 07:28 PM
AlfonsoR's Avatar
Any idea on why the seal started leaking?
If the cam shaft is worn in the seal area, then popping in a new seal may not help very much. You may want to try to install the seal so that it rides on "virgin" material or you may try speedi sleeve.
Speedi-Sleeve shaft repair kits
"Simplicity is supreme excellence" - James Watt
Old 11-24-2012, 10:13 PM
Red Line Service
Marc Bixen's Avatar
Drill a small hole in the metal area of the seal. Screw an appropriate sheet metal screw in it and pry it out with a pair of needle nose pliers. No damage to the camshaft and no damage to the cambox bore.
Marc Bixen/Red Line Service
West Los Angeles, Ca.
www.redlneservice.net / info@redlineservice.net
Podcast:"Marc Bixen Live"
https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA
Old 11-24-2012, 10:26 PM
Red Line Service
Marc Bixen's Avatar
How ya doing Drago?? If you haven't heard, we relocated to West L.A. Robertson Bl exit of the 10 Fwy to be more specific, 3387 Livonia Ave. L.A. Sounds like you had a fun Thanksgiving Cruise. Too bad about the boys that got pulled over.
Old 11-24-2012, 10:29 PM
DRACO A5OG's Avatar
Listen Dr Marc that is a sure way to get that seal out. He saved my arse more than I can say
Hey Dr Marc, I am going to stop by CONGRATS on your new Shop Locale, yeah Jim (nameisbauer) and I had a bit of a scare when a fella in his slantnose lost his rear end around a hair pin and did a 180 right in front of use, of course I was sandwiched between them
Over all it was VERY FAST and FUN
'85 Carrera Targa
PCA/POC
Old 11-25-2012, 09:48 AM
