Always Be Fixing Cars
964 timeline of improvements / problem years?
Hi all
I'm looking for a timeline of 964 development that charts which years were affected by 964 unique problems such as the flywheel and oil control gaskets, in addition to any other mid-generation changes for the better/worse to look out for. thanks r |
Banned
The book is worth every penny. |
PhD on Pending Projects
Not to send you to another site, but I have documented most of the stuff I have done to the car.
Pending projects and a few q? - Rennlist Discussion Forums There are some specifics for the first year... different parts for the '89. Then you have the heads on the early cars with not sealing rings. This was mid 91 year cars... Updated clutch release fork. Need to install a vent kit for the distributor to avoid the degradation of the belt that drives the second distributor. Technical bulletin for the plug that goes into the airflow meter. Quote:
Drive safe! 1967 - Porsche 912 1981 - Porsche 911 SC 1991 - Porsche 911 C4 Wide-body Cabriolet |
If it is a cabriolet that you are looking at, check the bolts on the top's transmission... you have one on each side. These come loose with time and need to be tighten...
Cabrio Top Mechanism Problems - Rennlist Discussion Forums
Details on the Erratic idle due to a connector
Also need to decide if you want a C4 or a C2... with the C2 being less complex than the C4.
Mine is a C4 and the system has been working fine so far. Only had one problem, I was using the car and had to make a sudden stop at a speed bump. The ABS came to play. Since it was the first time I had sense the system in action I decided to give it another try. It worked flawlessly. Close to my house I made a normal stop and to my surprise the brake pedal would not respond. I had to push it extremely hard to make the car stop. The problem was solved by: Pressure Sensor replaced(US$247.55 - Part # 964-606-904-00), Relay replaced (US$33.81 Part # 964-615-135-00), Rubber O-Ring replaced(US$4.99 Part # 999-707-094-40). Labor US$147.90 Minus PCA discount. But, like I said, you are exposed to more potential issues with the awd system. For example, the solenoids that activate the front drive are over 300.00 each... and I have not found a way to rebuild them... Oh, another thing I forgot... AC blowers. Two in front, one on each side... bearings go bad and you need to replace them... another 4-500 for each blower... Also the evaporator is a b* to replace, ask me how I know... but it can be a diy task and avoid paying for the labor (very labor intensive). Fuel smell from either a bad gas cap, bad fuel filler neck, or evap valve, or old hose under the front trunk...
Drive safe! 1967 - Porsche 912 1981 - Porsche 911 SC 1991 - Porsche 911 C4 Wide-body Cabriolet Last edited by wachuko; 11-27-2012 at 12:22 PM.. |
Steering rack is another issue to look at... no updates that I am aware... and still waiting for a vendor to sell a rebuild kit specific to our 964... the ones that I have found are only for 993 racks... not the same.
Here is a good thread on rebuilding a steering rack, again, for a 993 993 steering rack DIY rebuild tutorial - Rennlist Discussion Forums
