Track Pressures for Yokohama A032
All, I was wondering what pressures folks are running on there A032's at the track. I'm looking for hot pressures and track temps.
CHeers, James
You will never know the feeling of a driver when winning a race. The helmet hides feelings that cannot be understood.
Ayrton Senna
1993 964 RS
Old 06-20-2002, 09:01 AM
Automotive Monomaniac
Emission's Avatar
Can you give us the tire sizes?
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)
Old 06-20-2002, 09:07 AM
tobluforu's Avatar
Per the track guru's on this board:
Yoko A032R Start Pressure?
Old 06-20-2002, 09:51 AM
A good starting point would be 34 rear 29 front , cold
Old 06-20-2002, 12:19 PM
Talk about timely! I'm going out on the track with my A032R's next week for the first time.
What, if any, adjustment should one use for larger tires?
I'm running 315/35-17 and 245/45-16. In "track trim," my car weighs just a little under 2600lbs
For the street, I'm running 32/36 My shoe polish markers haven't even been touched even with some aggressive on/off ram driving.
Old 06-20-2002, 12:53 PM
Men, Thanks for all the responses...Thom, remember that if the ambient temp is high adjust your cold pressures accordingly. For example, I was running at Mt. Tremblant when it was 45deg out, I set my tires(Michelin Pilot Sport Cups) at 30psi and they only got to 35psi after 15laps. This was perfect since they only need to be at 35psi anyway. Good luck!!
Cheers, James
Ayrton Senna
1993 964 RS
Old 06-20-2002, 01:49 PM
