-   -   Still missing after DME relay, plugs, wires, Dist. cap & Rotor? (http://forums.pelicanparts.com/porsche-911-technical-forum/720370-still-missing-after-dme-relay-plugs-wires-dist-cap-rotor.html)
Booney1golf 11-29-2012 02:36 PM
I have an 87 911 3.2 that was running fine then I went about 3 months without driving it more than just starting it in the garage every 2 weeks or so.
I started it and it was missing some so I decided to change the wires, plugs, dist. cap and rotor & DME relay since I was not sure how long it had been. The car may run better but still has a slight miss when at idle or even when driving normally. The car seem to pull strong when I get on it but several people have heard the car and seem to think its a fire and not a fuel issue. The Fuel filter was also changed recently.
I thought about changing the coil but I hate to keep guessing due to all of the sensors, etc..
I'm trying to avoid just taking it to a shop but I might have to unless someone has something relatively inexpensive I can try.
Thanks for your time in reading my post!
Daniel Womack
1987 Porsche 911 Cab Wide-body
1998 BMW M Roadster
I love speed!!!
DRACO A5OG 11-29-2012 06:19 PM
Check the ohms on the ref/speed sensors.
Flat6pac 11-29-2012 06:31 PM
sounds like you have a non firing injector. They get that way from sitting, even a short time. Tap it, they will come alive.
Bruce
kodioneill 11-30-2012 05:22 AM
Possible that you may have a vacuum leak. Sometimes the brake booster hose get's brittle and cracks on the back of the engine. Acquire a vacuum gauge and check manifold vacuum at idle should be near 18 hg.
Chuck.H 11-30-2012 05:59 AM
Bruce
To test this theory you can feel or listen (with a stethascope) to each injector - they make quite the clicking when they are functional.
Another test you can do is to get an infrared thermometer and look at each exhuast port to check temperatures - a non firing cylinder will be colder than the others... this is a good way to isolate bad injectors, spark plugs or plug wires.
Chuck.H
'89 TurboLookTarga, 342k miles
T77911S 11-30-2012 07:15 AM
drive it and then pull the plugs. also check for air leaks. check the intake bolts. injector Orings too. you may just have a smoke test done,
Booney1golf 11-30-2012 08:06 AM
Thanks to each of you. Some of these things I can do others are out of my knowledge scope. I will go forward with what I can and report back.
I appreciate the time spent reading and responding to my post!.
Daniel Womack
1998 BMW M Roadster
I love speed!!!
Jim Richards 11-30-2012 08:36 AM
How old is the gas?
How's the O2 sensor?
Quicksilver 11-30-2012 09:55 AM
Sent a PM
Booney1golf 12-07-2012 07:51 AM
Thanks again for all of the help / responses. I put 1/2 tank of Super unleaded then added 12 onces of Lucas gas treatment and drove the heck out of the car once it warmed up.
The feeling of driving a Porsche that is running as it should: Priceless!!!
Thanks again to each of you through the years that have helped an average non mechanic be able to drive and own 4 different 911's!!!
Daniel Womack (Booney1golf)
1998 BMW M Roadster
I love speed!!!
