Still missing after DME relay, plugs, wires, Dist. cap & Rotor?
I have an 87 911 3.2 that was running fine then I went about 3 months without driving it more than just starting it in the garage every 2 weeks or so.
I started it and it was missing some so I decided to change the wires, plugs, dist. cap and rotor & DME relay since I was not sure how long it had been. The car may run better but still has a slight miss when at idle or even when driving normally. The car seem to pull strong when I get on it but several people have heard the car and seem to think its a fire and not a fuel issue. The Fuel filter was also changed recently. I thought about changing the coil but I hate to keep guessing due to all of the sensors, etc.. I'm trying to avoid just taking it to a shop but I might have to unless someone has something relatively inexpensive I can try. Thanks for your time in reading my post! Daniel Womack 1987 Porsche 911 Cab Wide-body 1998 BMW M Roadster I love speed!!! Last edited by Booney1golf; 11-29-2012 at 02:38 PM.. |
Member 911 Anonymous
Check the ohms on the ref/speed sensors.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
sounds like you have a non firing injector. They get that way from sitting, even a short time. Tap it, they will come alive.
Bruce |
Possible that you may have a vacuum leak. Sometimes the brake booster hose get's brittle and cracks on the back of the engine. Acquire a vacuum gauge and check manifold vacuum at idle should be near 18 hg.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera Last edited by kodioneill; 11-30-2012 at 05:24 AM.. |
Another test you can do is to get an infrared thermometer and look at each exhuast port to check temperatures - a non firing cylinder will be colder than the others... this is a good way to isolate bad injectors, spark plugs or plug wires. Chuck.H '89 TurboLookTarga, 342k miles |
drive it and then pull the plugs. also check for air leaks. check the intake bolts. injector Orings too. you may just have a smoke test done,
Thanks to each of you. Some of these things I can do others are out of my knowledge scope. I will go forward with what I can and report back.
I appreciate the time spent reading and responding to my post!. Daniel Womack 1987 Porsche 911 Cab Wide-body 1998 BMW M Roadster I love speed!!! |
Bandwidth AbUser
How old is the gas?
How's the O2 sensor?
Jim R. |
Diss Member
Sent a PM
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Thanks again for all of the help / responses. I put 1/2 tank of Super unleaded then added 12 onces of Lucas gas treatment and drove the heck out of the car once it warmed up.
The feeling of driving a Porsche that is running as it should: Priceless!!! Thanks again to each of you through the years that have helped an average non mechanic be able to drive and own 4 different 911's!!! Daniel Womack (Booney1golf) 1987 Porsche 911 Cab Wide-body 1998 BMW M Roadster I love speed!!! |
