-   -   electrical problems...HELP (http://forums.pelicanparts.com/porsche-911-technical-forum/72047-electrical-problems-help.html)
82SC 06-20-2002 02:41 PM
well my SC is acting up...
I put on early heat excahngers and a dansk muffler...and I never had time to get the CO adjusted...and the O2 sensor is plugged in but is not screwed into the HE's
so I used to have a really bad idle at stop lights...and my car stinks cuz I think it is running too rich...
I adjusted the idle screw to 900RPM...
but sometimes (usually cold start) the idle is erratic...which I expect
but then sometimes my tach starts swinging wildly...my guages and light dim-brighten-dim-brighten
and my radio dies??
is my alternator shot (it is a brand new...1 year old...replacement) and the alt light does not come on...
when I rev the car the lights get steady and the radio comes back on....
any idea?
thanks
MJ
nhromyak 06-20-2002 02:49 PM
Check voltages.
Mine did this too at idle. I finally checked it and found I was getting ~17 volts at idle....
I decided to check it, after my amp blew out... :(
RoninLB 06-20-2002 07:08 PM
82SC..there's something about the commonality of your elec. prob. that leads me to a ground..just a guess, assuming routine checks have been done.....Ron
