-   -   SCCA STR Autocross Carrera Build (http://forums.pelicanparts.com/porsche-911-technical-forum/720521-scca-str-autocross-carrera-build.html)
aschen 07-01-2014 06:21 AM
I would absolutely love to see this car in the trophies at some point. I think it is an uphill battle but, most of the good fights are.
I think LSD will be worth alot of time as well.
BRAIDusa 07-01-2014 07:31 AM
Likewise.
LSD is on my list, precipitated by the recent demise of our transmission.
Trackrash 07-01-2014 07:50 AM
I'd love to do a PCA autocross, but neither of the Detroit area clubs seem to put them on.
That's too bad. In San Diego the autocrosses at Qualcomm are legendary, with average attendance around 100 cars and the track is over a mile long.
https://plus.google.com/photos/105776011673223522600/albums/6017151612314142481?banner=pwa
I'm now in Nor Cal which has a fun venue at Sonoma airport. Last AX we got 15 laps.
http://forums.pelicanparts.com/uploa...1404229777.jpg
As far as exhaust options for your Carrera, you may want to post something in the AX forum.
Just remembered there is a guy in SD with a Carrera that has had his Ring and Pinion replaced with the 7:31 from the earlier cars. He is wicked quick. Might be something to consider if rules allow it.
Also, you may want to research the LSD. Some say it hurts turn in on autocrosses.
Bleedsblue 07-01-2014 08:41 AM
I've followed this thread with interest for awhile now. I just started autocrossing my '86 coupe in C-Street (RMS region). It's relatively heavy @ 2700# (1/4 tank of fuel w/ full Griffiths A/C, original Carrera tail, sunroof, power seats, etc) but it does have a factory LSD, short shifter, and seems to be a strong engine even at 135k original miles.
Moving up slowly in the C-Street ranks, but still behind (from a driver perspective, not the car's fault) the top 370z/Toyabaru twins/RX-8s. Only done two events so far and I'm also on Continental DWs, while everyone else has ~200 TW tires. I only have one set of wheels for now and the weather in CO is pretty unpredictable.
I am considering a switch to STR primarily to use Recaros for headroom (1st priority) and weight reduction, so your thread is perfect inspiration. I don't have the money to properly prep for STR this season, but it's in the cards.
Keep it up! :cool:
Driven97 07-01-2014 09:30 AM
^Thanks, that's much appreciated. That's been my goal with this thread.
Also: I need to move to California.
Mr. Merk 11-16-2014 03:01 PM
Same here^
Except I haven't done any events yet. My car only has 25k on it but everything is old, even the tires (22yrs)
I lowered it, spaced the rack and did a dynomax exhaust.
Re11s asap
I'm fairly certain it has 7s, 8s and LSD, otherwise optioned the same as yours.
DG624 11-17-2014 04:27 PM
Matt,
You seem to know how to drive the car...that is half the battle. I reduce weight down to 2500 lbs without driver. I also did all of the basic maintenance items along with a fuel injection clean and balance by Marren. The engine is now putting out over 250 HP at the clutch.
My suspension rebuild is progressing with new rear T-bars, all new bushings and rear monoball by Rebel Racing. I will replace the rear sway bar and then try to see how it is improved. I think I can get the body roll down to the 3-4% range.
Driven97 11-17-2014 05:40 PM
Thanks for the kind words all. I'm working on a few tricks this off-season. SCCA national schedule just came out and looks like I may do as many as six national events this coming season.
The diff is awesome, but needs some setup changes to take advantage of fully.
winders 11-17-2014 05:47 PM
For autocrossing, I would not get an LSD. I would get a torque biasing differential from Guard Transmission.
Driven97 11-17-2014 06:20 PM
I wanted the locking in off throttle, car was super unstable in braking while turning. I couldn't attack certain elements like I wanted to. Helical lsd couldn't give me that.
I went with a kaaz. Reverse 1.5 way, 1 set of plates disabled, softest preload springs.
Really stabilized the car, I can push it much harder. Picked up some push in slow corners though, conditions match to much preload.
I'm hoping the diff will break in as I can't lower the preload any more. I have a larger rear bar I'm going to try next season as well.
Unfortunately the off-season is long.
Driven97 02-01-2015 08:24 AM
Ok, so STR rules allow for up to 9" wide wheels and up to 255 width tires. I've been running 225s on 7" Euros so far, which is obviously leaving time on the table.
Biggest I can find under a stock Carrera flare is 245s on 8" wheels. And even then it has to be perfect.
I have a friend who lent me a 17x9 ET55 Cup wheel for some test fitting. He had a Michelin 255 width tire on it. Took 20mm of spacer to make it fit, so 17x9 ET 35 equivalent:
https://lh6.googleusercontent.com/-K...o/IMAG1108.jpg
Virtually zero strut room. I removed my metal cans and have 4x4 offroad boots.
https://lh4.googleusercontent.com/-e...o/IMAG1104.jpg
Spins totally freely though. It actually turned with 15mm of spacer, but rubbed the boot audibly.
https://lh4.googleusercontent.com/-5...o/IMAG1110.jpg
It's hard to capture in a picture, but with camber and rolled fenders looks like I have plenty of clearance on the outside. That's with the front torsion lever cranked all the way down. Proof of concept success?
So question is - do I go full nutjob and have my front wheels widened to 9", or do I just so mostly stupid and go 8.5"? If the 9" looks like it fits, 8.5" should be a cakewalk, no?
jjeffries 02-01-2015 08:52 AM
Matt, fascinating process you've been going through, sort of a Zen path of continuous exploration for the ultimate balance / performance. Must be fun and maddening in equal measures. Nice work. John in CT.
Elombard 02-01-2015 08:59 AM
"obviously leaving time on the table".
Matt I am going t question that statement. I am all about big tires but I think racers want the least amount of tire they can get away with for their car weight, power, balance etc. Right??
Less weight, less rolling resistance, cheap way to get a better gear ratio? I remember reading one time a guy was running a solar racer with bicycle tires because for that race that was the sweet spot.
Not sure how you evaluate that? I guess it would be trying different sizes and comparing lap times?
I noticed that the performance on my 73 noticeably dropped off in every way when I went from 15x7,8 fuchs to 16x7,8 panasport imitations (heavier and taller and I was able to run a 245 tire and not a 225.
msterling 02-01-2015 09:12 AM
The 255 michelins might fit but ZII or Rival or R-S3 might not (or might fit better). Also the tires deflect under load and may rub if you are that dang close. 245 is a better bet. 8" or 8.5" should be enough for a 245 tire. TireRack has some pretty good info on actual tire dimensions.
I still think you would be faster on 15s. Faster accell, lower unsprung weight and lower car. Hard to get more 15" rubber on the road but still may be worth it. This year I will be able to compare 225/45-15 Rivals on 7&8 Fuchs to 225/45-17 & 255/40-17 R-S3s on 17x8&9 Euromeisters. My guess is the 17" setup will be slower despite the extra rubber. I will need to include more negative camber and rolled fenders up front before the 17"s fit properly. The 17" wheel and tire assys. are HEAVY.
Driven97 02-01-2015 09:45 AM
Yeah, I'm not sure. Really entering uncharted territory. AX tends to favor pure mechanical grip. Acceleration is important, but not the end all be all. Otherwise 97hp Civics and 115hp Miatas wouldn't be as fast as they are. I figure why give 2" of wheel width to my competitors - they're all on 9" wheels all around.
At higher speeds, the fronts on a 911 don't seem to be quite as important. They more request slip angles for the rear tires. At AX speeds I'm really leaning on the fronts. I've been trying to tune around that, but I think I'm reducing rear grip to get my intended balance.
So I'm leaning towards trying the 9". Even if I drop down to a 245 or even 235 the much squarer sidewall should give me an advantage over the pinched 225 on the 7" wheel.
Driven97 02-01-2015 09:52 AM
...225/45-17 & 255/40-17 R-S3s on 17x8&9 Euromeisters. My guess is the 17" setup will be slower despite the extra rubber. I will need to include more negative camber and rolled fenders up front before the 17"s fit properly. The 17" wheel and tire assys. are HEAVY.
Euros are 7&9, not 8&9. That's the setup (including tire size) I run now. They fit on my car without any roll and stock camber plates maxed out with just barely grazing the LH fender lip. No issues with the spherical bearing camber plates.
If I could get a legal short 255 15" tire I'd totally rock it. Thrust charts look pretty awesome.
FWIW, Toyo makes the R1R in a 245/35-17. That's quite a bit shorter than the 255/40. It's been updated to 200tw this year, so legal for ST. Supposedly the compound didn't change though, so it would hate the back of a 911.
RichardNew 02-01-2015 10:51 AM
You've picked a really tough class. The S200s and Miatas are very difficult to beat. The fast guys usually pick the fastest car in the class if they want to win. I've seen national champions switch marques in the middle of the season. The fast guys have zero marque loyalty.
At least you're having fun. One problem you're going to encounter - if you haven't done so already - it the PCA rulebook. PCA and SCCA rules are different enough to require different approaches. Our local PCA finally threw in the towel and we now run SCCA rules.
Richard Newton
BRAIDusa 02-01-2015 03:40 PM
Matt knows, I think, that I fall in the camp of lower weight and lower gearing of 15" wheels and tires. That being said, Matt is optimizing his car purely for SCCA STR autocross while I'll throw my car at anything it's legal for including RallyCross.
FWIW I'm going up to 17" this year (not for rallycross) but not from a performance standpoint but to promote our new 17" replica wheels. Sorry about hijacking your thread for the blatant plug Matt but if you'll consider using a pair of our 17x9 at what ever offset you need rather than cutting up and welding up some other wheels (a dubious practice IMHO though I have seen no data to suggest it's not appropriate) I'll cut you a really good deal. There, now we are even LOL.
Eric 88 Carrera 02-01-2015 06:18 PM
I saw a big difference going to a square set up using 16x7's running 225's. It made the car much more balanced and neutral than my previous set up of 205's and 225's. It probably improved my times by 1 second on a 60 second course. Alignment makes a big difference too. There is very little under steer during the typical autocross course.
Bleedsblue 02-01-2015 06:26 PM
BTW, Euro offers a 17x8, though it is rear fitment (et10.6).
I agree that the RS3, ZII, etc will run wider than the 255 Michelin (according to Tire Rack specs and friends who have compared), so I might go for a 245 up front. Then an 8.5J wheel would be perfect and give you a bit more breathing room.
I'll watch this with interest since I agree the lack of front tire (in autocross specifically) leaves performance on the table.
Since I'm probably not getting new wheels this year, I plan to go with 225 all around on my 7s and 8s, maybe the shorter 225/45/16 Dunlops, but I'm also limited in CS. I've been running 205/225 but want the extra bite up front the post above me is referring to.
winders 02-01-2015 06:35 PM
On a 911, a square setup is only desirable when you don't have enough roll resistance at the rear. In other words, you are fixing an imbalance by making using the same size tires front and year. But clearly, for better performance, you want larger tires at the rear since most of the weight is back there. You adjust chassis balance with roll bars or torsion bars.
Driven97 02-02-2015 04:27 AM
I love ya Paul, but Braid BZs look like they're out of my price range by like an order of magnitude of five. The 930 front 17x9 ET30 is pretty damn close to what I need though. Plus they look really pretty. When do the first 17s start coming off the presses?
And as always, I may not do things the right way, I do them my way. If some of you armchair quarterbacks don't like the way I'm doing things, you're welcome to come and try to beat me. I plan on being at SCCA Nationals this year, along with all the midwest Pro Solos, Match Tours, and Champ Tours. I'd love to not be the only 911 in the STR grid for a change. I stick out like a sore thumb. Hell, I'm usually the only guy with a roof. Until you beat me, I get to call myself the fastest STR 911 on the planet.
http://i57.tinypic.com/2ltn4o.jpg
BRAIDusa 02-02-2015 10:46 AM
"Wheel" see what we can do Matt. I still owe you something for those torsion bars anyway. We can offer variable offsets on the 17" BZ now without the extra charge it takes on the 15" and 16". Not only that we can make 964 and 993 compatible offsets too! Maybe even 996! Widths from 6" to 12".
I should get a sample prototype this week while four others are being tested in the lab. Assuming they pass I think we can start shipping wheels in about a month. Got to be better than welded up old wheels right?
I won't be joining you in the STR grid. As you know I'm way beyond STR and yet way too slow at the same time.
Driven97 05-18-2015 05:53 AM
Just to update this, I've made some large changes to the car.
I did go nearly square - 245/255 Bridgestone RE-71R. I'm on class max 9" wheels all around.
Over the winter I went to chase down my front suspension noises and realized my front swaybar bushings were likely binding a little.
https://lh6.googleusercontent.com/-g...o/IMAG1135.jpg
All the grease was gone, but I also didn't notice that the bushing was quite a bit too large for it's mount. I sanded it down to actually have a slight clearance, and greased the hell out of it to boot.
Well, the thing had to be clamped rock hard, because doing that turned the car into a wild oversteering beast. Not even drivable. A friend calculated the spring rate of the fully bound swaybar at something like 12,000lb/in!! No wonder I couldn't get rid of understeer, my front suspension hasn't been working at all for the last two years.
So I hit the reset button quite a bit. Went back to something similar to my first guess setup:
23/33 t-bars
Big front bar
OE rear bar (with spacered to flat-based and sanded down poly rear bushings)
I was treated to a 911 that was actually balanced, with slight oversteer in sweepers, for the first time ever yesterday. I actually want to tighten the car up slightly now. Braking performance has improved 10x. The car is a completely different animal, drives like a real autocross car now. This project has a brand new lease on life.
I feel pretty stupid that I didn't notice the bind for years, but boy am I glad I've fixed it.
tl;dr GET RID OF THE BIND IN YOUR SUSPENSION
car @ work:
https://lh4.googleusercontent.com/-s...ac18ac3b_o.jpg
Driven97 08-03-2015 08:37 AM
https://lh3.googleusercontent.com/-3...84837062_o.jpg
Well, I guess you can say I can generate some grip.
A few notes / things learned recently:
- The new crop of 200tw tires is insane. The RE71R is a longitudinal monster - even S2000s are nearly matching my 60ft times now, which eliminates my advantage at pros. The Rival S on my car is much easier to drive fast as it's more forgiving to slip angle overshoots.
- The KAAZ lsd works beautifully. At full steam my inside rear is barely touching the ground and I have no problems putting power down. The stability off throttle is lovely. It's holding up great to some hard work. I'm impressed.
- After driving a couple of "real" STR cars (Miatas) I'm fairly confident that my current shock valving is insufficient. The Miatas reacted right now where my car has a long lag time. I can hear the tenths of a second clicking onto my time every time I turn the wheel. The 911 is by far the narrowest car and should smoke the other cars in slaloms, but that feels like the weakest element in the car right now.
Digging a little deeper and I have virtually zero compression damping, where the fast cars run very high low speed compression with a heavy digressive cut. Wallet back open again. FWIW my 23/33 combo is on the low end, but supposedly within range of the spring rate per lb of the fast cars.
Still off the pace of the NC / S2k but right now I really love driving the car. It's difficult as hell compared to modern cars, but super satisfying when you get things right. I'm registered for Nationals so we'll see just how close to DFL I get against the best in the country.
winders 08-03-2015 08:50 AM
What I see in that pic at the rear is typical for a 911 with good tires. What I see at the front tells me the car is much more roll stiff at the front than the rear. Think about it, you only have one on the ground up front. You are giving up grip because of the other choices you have made. If you want to be as fast as possible, you want that front tire on the ground. That means stiffening the rear or softening up the front. But, to keep reasonable chassis balance, that means you need more differential in tire size front to rear. Why would you want to run a near square setup in a car with so much weight at the rear??
Driven97 08-03-2015 09:09 AM
I'm limited to 255 on 9" max per rules. I can reduce the front, but not increase the rear. Would the car be faster reducing front tire?
Trackrash 08-03-2015 09:23 AM
Good to hear things are working out well in this update.
911s are going to lift the inside front tire at times.
The big question is; how is the car on corner exit? If it isn't pushing to bad you are well set up IMO. Getting the power down ASAP is key. Looks like you are good in that respect.
If you are running Bilsteins, custom valving is what most have success with. Adjustable Konis may be something to consider, if rules allow. But that is just another thing to fiddle with...
Last911 08-03-2015 09:24 AM
Originally Posted by Driven97 (Post 8141571)
Put in one of those freaks of nature drivers too, and maybe, just maybe, a Carrera could be nationally competitive vs. the S2000 / NC Miata.
I autox my NC Miata and it seem sooo easy. I'm not a good driver at all, but your thread gives me hope! I might take out the 911.
But I am filled with worry. I'm worried something might happen to my 2.7 headstud puller. You have a nice solid 3.2, should I be worried, or just rip on it?
Anything you've done to protect the engine?
Edit; Also, how exactly did you figure out the front end was binding? Just from removing the mount? (Sorry I'm a newbie). That's why I like the NC, it's already 'set up', it's pretty hard to screw up. I don't want to start messing with my 911 and make it worse.
What's the first few things you would do to a stock 911? :)
rennch 08-03-2015 09:34 AM
You are absolutely right about the Bridgestone RE71R. They are hilariously grippy. They feel like a Hoosier A6. I have them on my Mini Cooper S that is prepared for STX and whipped up on people I was previously a second behind. No WAY are they legal next season.
Driven97 08-03-2015 10:32 AM
Balance on exit is very dependant on how I got there. Rolling onto the gas from a sweeper, it will push lightly. Romping the gas upsets the front and induces big push. On throttle in transition exits the car is a raped ape - plant the foot and be ready with a little counter if needed. A few people commented how strong my car looked on exit, so I guess I'm pretty good there.
Rear shocks are ordered - I'm trying some Hotbits from a fellow Pelican. I asked Chuck if he'd be willing to try revalving my Bilstein fronts with more compression, and I apparently offended him as he said he's not interested in being involved with the type of valving I was requesting. Maybe I'll send them to Bilstein themselves in the offseason.
I know nothing about the 2.7, sorry. I've done nothing special to my motor.
As far as the front bar, it was squeaking pretty bad since not long after the install. I intended just to regrease the bushings last winter, but remember seeing an article about binding with oversized poly bushings somewhere online. I did NOT expect sanding down 2mm of poly could have so huge of an effect. It was massive, like hitting the reset button on the whole car.
Yeah, they're real monsters. But since they fit the 200tw rules, and seem to work very well all the way down to the cords I don't see much of a case to ban them. Looks like I'll get a full season out of my rears, exactly what I got out of the Z2s I ran last year. Honestly, I think the Rival S is just as fast on certain types of cars as well.
winders 08-03-2015 11:05 AM
You are effectively doing this on your own by having the front so stiff compared to the rear. This means you are losing compliance in the front which can have a dramatic effect on how the car performs unless all the courses are glass smooth.
I think you would be faster with 225's on the front and the front end would be more compliant because you would have to soften it up to maintain the chassis balance you have. You will still lift the front tire, but not as often and not for as long.
Driven97 08-03-2015 11:12 AM
Interesting - so if I were to go narrow and soften, would I soften spring or soften bar? Or both?
winders 08-03-2015 11:25 AM
I would start with the sway bar....also, if you add compression damping like you are talking about doing, you would need to soften the bar more yet.
How much room do you have to soften the front bar?
westcoast911 08-03-2015 11:28 AM
My favourite pelican thread- just sayin.
Driven97 08-03-2015 11:43 AM
I have to stay underbody, so I have a 22.2mm bar on. I do still have the OE 20mm bar.
winders 08-03-2015 11:56 AM
Is the rear bar adjustable?
Driven97 08-03-2015 02:11 PM
No, but I have two of those as well. OE 18mm and a 22mm.
BRAIDusa 08-03-2015 02:46 PM
You can borrow my 225 Rivals.
Driven97 08-03-2015 03:44 PM
I have 225 Rival S. I was slower on those than the Bridgestones.
