"O Gruppe 13"
IDGAF27's Avatar
Send a message via Skype™ to IDGAF27
Question 915/44 Trans question
I had look through threads, that come up in search, but failed to find photos of LSD while not removed.
I had this transmission laying in a garage for some while. Want to know, is it LSD or No LSD . So i did open it and this is what I found.
Question is : what do I have in here ?
G-Man
89 964 C4
86 930
Old 11-26-2012, 12:31 PM
Capitalist and Patriot
911Freak's Avatar
You could have tested it without opening her up...spinning the axle flanges, if they move same direction, LSD, if they spin opposite open diff..
Anyway now that's open I think you need to pull the diff out to see the other side as that's where the LSD would be. Can't tell from that side to my non-expert eye.
Maybe one of the guys can tell from that view?
Good luck.
Former Test driver & Production Manager Singer Vehicle Design
2009 Cayenne GTS, '81 911SC RoW Targa (lot's of goodies), '86 535csi, '84 633 csi (turbo charged-sold) , '68 912 Targa (sold) , '69 911E (sold)
"Dream it, Believe it, Decide it, DO it "
Old 11-26-2012, 01:02 PM
Bill Verburg's Avatar
I can't tell from that pic, maybe someone smarter can
If you pull the assembly it is going to be obvious
a 915 ZF looks like this
If the lsd was oe there would be a 12 stamped on the bottom after the type # like this
915/63 no lsd
915/73 w/ lsd
Bill Verburg
"O Gruppe 13"
IDGAF27's Avatar
Thanks Bill, I have seen those photos . There is no marking on case, that is the reason I open the case.
Will stick to suggestion to "pull it out". I am more than half way there anyway.
Thanks.
G-Man
89 964 C4
86 930
Old 11-26-2012, 01:10 PM
47silver's Avatar
hi was it lsd?
hi
did you get a chance to determine if it was lsd? i have a sporto that is not marked with a 12 and both axles spin in the same direction as if it were an lsd.
1975 911S Targa
Silver Anniversary Edition
Old 12-04-2012, 03:47 PM
