Member 911 Anonymous
DRACO A5OG's Avatar
Angry Brake Line Leak Found :-(
While working on a new fuel pump, look what was hiding behind the stone guard
I am not liking the rust at the elbows and end of the hard lines. Guess what my next project is.
Damn East Coast Car.
'85 Carrera Targa
PCA/POC
Old 12-11-2012, 08:47 PM
Send a message via Skype™ to Porboynz
The flare on the end of that leaking brake pipe may have cracked. Unless it was left accidentaly loose from previous maintenance/work they rarely leak like that. I would get a proper brake pipe flare nut spanner on it and check tightness. (You can quickly check the tightness with a regular spanner if you do not have the correct brake pipe type with the opening) If the nut is tight but leaking I would undo it and inspect the flare end of the pipe closely. If you wedge the brake pedal half way down the fluid leak will be minimal. I would be less concerned about the rusty flare nut fitting as there is a lot of metal there. Clean it up and paint it because changing the brake line that goes through the tunnel is a hassle. Rusty brake pipes are another story, they should be replaced.
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 12-11-2012, 09:32 PM
DRACO A5OG's Avatar
Thanks for the tip, I am going to check out the top next to the MC and BLS's to see if those are weeping.
Oh the joy.
'85 Carrera Targa
PCA/POC
Old 12-12-2012, 12:05 AM
