drag racing the short bus
dd74's Avatar
Weight of Fuch wheels
Does anyone know the weight of 15x7 and 15x8 and 16x7 and 16x8 Fuchs per wheel?
Thanks in advance.
Old 06-22-2002, 12:34 PM
Eric Coffey's Avatar
Porsche Crest
Fellow board member Sherwood Lee has a great 911 wheel info page on his website. Here's the direct link:
http://members.rennlist.com/911pcars/WheelWts.html
Old 06-22-2002, 01:13 PM
Plavan's Avatar
I'm sorry but that chart is WAY off on some wheels. I just weighed my 16x7 inch Fuch and it is 14 pounds not the 18 pounds listed. (Nice digital scale). I thought it was fishy when it lists the 15x7 wheel as 12 and a 16x7 wheel as 18!!!!
Someone needs to double check everything else on this chart.
Chad Plavan
911ST Race Car/2.5L SS Race Motor #02
1972 911T- Numbers matching- Restoring to stock
2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold)
2016 Elan NP01 Prototype racecar- Chassis #20, #02
Old 11-27-2004, 07:03 PM
rdane's Avatar
This from a calibrated mail scale:
Fuchs 7 x 16 14.75#
Fuchs 9 x 16 16.5#
Old 11-27-2004, 09:57 PM
dd74's Avatar
Uh-oh! And I passed up all those 16-inch rims because I thought they were TOO HEAVY?
Thanks, Dane! You just ruined my Kettle One vodka buzz.
BTW: the 15x7s and 8s, and similarly-sized Minilites are correct. I weighed them once at TRE. Minilites are fairly heavy.
The Terror of Tiny Town
Old 11-27-2004, 10:02 PM
rdane's Avatar
Sorry David, no one deserves that
Here are some weights I have been getting with the wheels and tires in my shop.
The SO3 numbers are estimates from Tire Rack, the Fikse wheels factory numbers, everything else is off my shipping scales. You'll notice some of the wheel and tire combos don't add up.
I know what the Fuchs, two piece Fuchs and Fikse weight with SO3s mounted and the 2 piece wheels with Victoracers. Next time someone tells you their wheels are lighter than Fuchs give them a little leeway but raise an eyebrow.
All of this is the reason I am still running original Fuchs..
(actual weights on my scales)
Fuchs 7 x 16 14.75#
Fuchs 9 x 16 16.5#
2 piece custom offset 8 x 16 Fuchs 18# (on my scales)
2 piece custom offset 9.5 x16" Fuchs 19.5#
(Fikse factory specs)
5 spoke Fiske 8" 18.9#
5 spoke Fiske 9" 19.6#
10 spoke Fiske 8 x 17" 17#
10 spoke Fiske 9 x 17" 17.8#
SO3 (tire rack est)
225/45/16 24#
245/45/16 26#
225/45/17 26#
235/45/17 24#
235/40/17 24#
255/40/17 27#
Victoracers (on my scales)
225/50/16 24#
265/45/16 27#
Mounted weights on my scales:
7 and 9 Fuchs with SO3s
225/45 38.5#
245/45 42.5#
custom 2 piece 16" fuchs and S03s on my scales
225/45 on 8" 40.9# per wheel
245/45 on 9.5" 42.8# per wheel
same Fuchs 2 piece with Victoracers on my scales
225/50 8" 42.4#
265/45 9.5 46.5#
Mounted weights of a Fiske 17" FM10 and SO3s on my scales
225/50 on 8" 42.4
255/40 on 9" 46.3
Old 11-27-2004, 10:14 PM
dd74's Avatar
Dane - where can I find those tire weights on the Tire Rack site? I've never seen them. Can you forward a link? I'd like to see the weights of 205-50-15, 225-50-15 and 225-45-15 tires.
Thanks. Great information as usual.
Old 11-27-2004, 11:39 PM
Fuchs w h o r e
Years ago I weighed a few wheels.
late 6x15s: 12.9lbs
late 7x15s: 13.5 lbs
8x15s: 14.0lbs
And recently a pair of 911R 7x15s were 11.7 and 11.9 lbs.
Mahle Gasburners beat them all, 9.7lbs!
Old 11-28-2004, 02:12 AM
rdane's Avatar
David, you have to call them and ask. Itt is only their estimate. They were more than a pound off on the Victoracers. One too much on the 225 and one to little on the 265.
Old 11-28-2004, 07:15 AM
Workboat's Avatar
Weight of 8x16 Fuchs
I have just weighed a pristine, almost new 8 x 16" Fuchs on a very accurate scale. The wheel is clean, has a stem in it and the stem valve support.
Porsche part # 911.362.117.00
Weight: 15 lbs. 5 oz.
"Hate to let a few facts get in the way of a decent rumour."
Dave
Old 06-16-2014, 06:30 PM
