Elombard's Avatar
broken exhaust stud drilling tool for rent?
Any body have a tool I could rent for a few days?
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 12-05-2012, 02:57 AM
kodioneill's Avatar
If you can't locate a tool it's easy enough to grind the stud flat , center punch and drill out using incrementally larger bits until you're almost to the threads then use a "easy out". I've done many like this with no problem the most important thing is to use good quality drills and make sure the center punch is as close to perfect as you can get it. Take your time it will work.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 12-05-2012, 05:01 AM
Elombard's Avatar
Yah thats my plan. i was going to get some left hand drill bits to try. I have used them before with some sucess although not in as critical an area.
The center punch location and getting the drill started straight will be key.
I thought I had the ultimate tool for this, it looks like a spark plug socket with rollers in side so it tightens up on the stud. I heated the aluminum with Map, installed and started turning. I thought it was coming out....just broke off :-)
I think I will try welding nuts on the end and using my impact. This tool does not work with an impact because it realeases when the pressure of the hammer action goes off.
Old 12-05-2012, 08:27 AM
ROW '78 911 Targa
timmy2's Avatar
Welding nuts on it should work well, a lot of heat gets transferred to help break it loose.
Old 12-05-2012, 11:17 AM
Insert Tag Line HERE.....
rattlsnak's Avatar
This is precisely why I didn't put headers on it when I had it.. Lol..
Old 12-05-2012, 08:23 PM
Elombard's Avatar
I know...I know cant leave well enough alone...I just hope it does not end in tears completely.
'But they were such a good deal'....yeah right.
Old 12-06-2012, 02:06 AM
