Mike80911's Avatar
Car will not shut off
I started my 88 the other day and drove for about an hour. All was fine until I got home and went to shut the car off I could not shut the engine. I removed the key and sat there for about 5 mins and the engine just kept running. All of the electrical items shut down, the tach shuts down and all lights shut down but the car keeps running. I finally pulled the coil wire to shut it down. Since this has happened I have started it several times sometimes it shuts down sometimes it does not. Has anyone ever run across this problem before? Any suggestions and what and how to check?
89 930 Cab Black
11 Cayenne
Old 12-06-2012, 06:17 AM
I'm not that familiar with the 930's, but on the 3.2's if the DME relay sticks in the closed position you may have this problem. But I have no idea on the turbo's.
Chuck.H
'89 TurboLookTarga, 342k miles
Old 12-06-2012, 06:27 AM
mmari270's Avatar
I had an issue where mine would not start and searched for "ignition problem". I read that the electrical portion of the keyed ignition switch goes bad. One guy gave the same issue where his car did not shut off.
Old 12-06-2012, 06:31 AM
Recreational Mechanic
Nickshu's Avatar
Sounds like a bad ignition switch. Not an uncommon issue.
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches
PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing
Old 12-06-2012, 09:40 AM
The Dude abides...
bigel's Avatar
I had a dream like that once.
'03 Carrera 4S
Old 12-06-2012, 10:14 AM
Mike80911's Avatar
My first guess was a bad ignition switch also I guess I will buy one and start from there. Hopefully that solves this. Thanks for the replies and advice
Old 12-06-2012, 02:21 PM
Nickshu's Avatar
Here ya go:
Pelican Technical Article: Replacing your Ignition Switch - 911 (1965-89) - 930 Turbo (1975-89)
Old 12-06-2012, 02:32 PM
dshepp806's Avatar
Yeap: ignition switch.
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 12-06-2012, 02:57 PM
muck-raker
kidrock's Avatar
quick note if the PO decides to replace the switch: the "nut" that holds the ignition switch onto the steering wheel lock is actually a locking nut, which locks an allen set screw (4mm, IIRC). Just loosen the nut, don't remove it. Then follow up by loosening the allen head set screw.
Also: I found that removing the steering wheel made the job of hacking the shear bolts a whole lot easier. I also found that drilling the middle of the shear bolts went faster and cleaner than cutting or grinding them with a Dremel tool.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 12-06-2012, 08:35 PM
