1 bar wastegate spring install
I replaced my stock spring with a 1 bar spring. It would of taken a total of 1 hr. to do but I had to get help to start the screws on the cover. It is a very heavy spring and takes about 150 lbs to compress. You will need help. My diaphram was good but my valve guide is bad so I will rebuild my wastegate next winter.
The results. I was getting 10 or 11 lbs of boost before now I get around 13 to 14lbs. My car pulls harder but not that much. It is more noticeable in the higher gears. I am not getting any pinging at all.
I did a mileage check today and I'm getting 9.5 mpg yikes but that is another thread.
I would do it again.
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 06-24-2002, 07:15 PM
Hilbilly Deluxe
emcon5's Avatar
Just because you can't hear it, doesn't mean it isn't pinging.
Did you do any other mods?
Tom
82 911SC Coupe
GTI Cup #43
Old 06-24-2002, 08:12 PM
yep
Intercooler
SS muffler
MSDal-6
Airfilter housing
Dean
Old 06-24-2002, 08:26 PM
