Replacing master cylinder and fluid reservoir.... do I need to bleed my clutch now?
Preparing for reassembly next week.
I removed the master cylinder and fluid reservoir to replace them. I disconnected the clutch feed at the reservoir only and haven't touched the pedal or anything else clutch hydraulic related.
Do I need to plan on bleeding the clutch once I reinstall everything?
'87 911 Carrera Coupe (go fast, small parts / small kids hauler)
'04 Toyota Land Cruiser (go slow, go anywhere, haul everything, the "AntiPrius")
Old 12-06-2012, 06:48 PM
non-whiner
mreid's Avatar
Yes, anytime you "open" the system you need to bleed it.
"Too much is just enough."
Old 12-06-2012, 06:54 PM
Meant to say I removed the BRAKE master cylinder, not the clutch. Still need to bleed the clutch since I pulled the clutch hose off the reservoir?
Old 12-06-2012, 07:01 PM
dshepp806's Avatar
YES!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 12-06-2012, 08:18 PM
Diss Member
Quicksilver's Avatar
You should be Ok.
As long as the fluid wasn't drained out of the hose down to the clutch master you then it didn't get into the cylinder. Any bubbles in that tube will rise up to the reservoir if you tap/shake the hose.
But...
How long has it been since you bled the clutch system? If it has been 2 years or more you are due anyway.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 12-06-2012, 08:35 PM
T77911S's Avatar
it never hurts to bleed some old fluid out. gets rid of the moisture and will make the entire system last longer.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 12-07-2012, 03:58 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Originally Posted by Quicksilver View Post
You should be Ok.
But...
I'm with Wayne on this one. The clutch is fine to leave alone if you're content with the fluid that's already in there. Removing the reservoir wont harm anything. The air bubble in the hose that results from filling the reservoir is well up the hose away from the clutch master, and should eventually rise up out of the hose.
Kevin L
'86 Carrera "Larry"
Old 12-07-2012, 07:41 AM
