Sticky Speedo
My speedo works, but usually needs a flick to do so. Otherwise it just gets stuck at the bottom showing no speed.
As soon as I go over 5mph if I flick it jumps into life. Anyone else have this problem and if so is there a simple solution (other than keeping on flicking it!).
Thanks.
A.
Old 10-18-2012, 03:59 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Check the simple things first.
Remove the gauge carefully by pulling out the clock then reach in and push the speedo out. Take care the wires are short.
Clean and polish all the contacts. The ground tend to be the culprit here.
Test. If still not working properly
Open the shift coupler panel at the rear of the tunnel at the back seat foot wells. Disconnect and Clean the contacts with contact cleaner from any flaps. When reconnecting make certain they are seat all the way in.
Raise the passenger side check the transmission signal contacts are clean and tight.
Test. If still not working. Then it may be the a loose green wire/s or broken solder on the green signal wire within the gauge like what I found. This requires the gauge to be taken apart, not for the faint of heart. re-soldered. All Good.
Hope this helps.
'85 Carrera Targa
PCA/POC
Old 10-19-2012, 10:44 PM
Bery many thanks for the advice - I shall let you know how I get on.
Old 10-22-2012, 03:50 PM
DRACO A5OG's Avatar
No problemo, post your findings brother to help others in similar situation:-)
'85 Carrera Targa
PCA/POC
Old 10-22-2012, 03:54 PM
Okay will do: &#x1f609
Old 12-11-2012, 02:24 AM
