-   -   Indentification of part? (http://forums.pelicanparts.com/porsche-911-technical-forum/723136-indentification-part.html)
wacko 12-10-2012 01:19 PM
Hello, Newby question. Can you please tell me what this part is the the black circle is around. There is a rubber boot around the wire connector and it has seen better days.
<a href="http://www.flickr.com/photos/89331859@N04/8261497881/" title="IMG_2206 b by hotcraig72, on Flickr"><img src="http://farm9.staticflickr.com/8360/8261497881_f7465e266d.jpg" width="375" height="500" alt="IMG_2206 b"></a>
ossiblue 12-10-2012 01:35 PM
That's the thermal time switch. It regulates current to some cold start devices, including the cold start valve by opening when the engine begins to warm and breaking the ground circuit.
wacko 12-10-2012 01:45 PM
Do you think it is possible this could cause a hesitation if it were to get wet when its raining hard?
howard freeman 12-10-2012 03:05 PM
No, will not cause hesitation.
Howard
ivangene 12-10-2012 03:13 PM
raining hard....check for water in your dist cap
ask me why :banghead:
plumb4u2 12-10-2012 03:14 PM
People usually say when you have that problem after it rains it's due to moisture getting into distributer cap
Most people say to remove cap and put some Vaseline around the lip
plumb4u2 12-10-2012 03:15 PM
Beat me
wacko 12-10-2012 03:16 PM
Ok thanks. Just eliminating possibilities. The rubber boot over the connectors is toast, is it worth replacing?
