wacko's Avatar
Indentification of part?
Hello, Newby question. Can you please tell me what this part is the the black circle is around. There is a rubber boot around the wire connector and it has seen better days.
IMG_2206 b
1978 RUF 911SCR
Old 12-10-2012, 01:19 PM
That's the thermal time switch. It regulates current to some cold start devices, including the cold start valve by opening when the engine begins to warm and breaking the ground circuit.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 12-10-2012, 01:35 PM
wacko's Avatar
Do you think it is possible this could cause a hesitation if it were to get wet when its raining hard?
1978 RUF 911SCR
Old 12-10-2012, 01:45 PM
howard freeman's Avatar
No, will not cause hesitation.
Howard
Howard Freeman
80 911 SC & 74 914 1.8
79 930 & 83 SC coupe,03 996 TT,02 996 C4
03 X/5 3.0. 370,186 miles now Sons daily driver
10 X5 3.0I 224,515 miles
Old 12-10-2012, 03:05 PM
ivangene's Avatar
raining hard....check for water in your dist cap
ask me why :banghead:
Ed M
86' Coupe
Old 12-10-2012, 03:13 PM
plumb4u2's Avatar
People usually say when you have that problem after it rains it's due to moisture getting into distributer cap
Most people say to remove cap and put some Vaseline around the lip
Justin
84 Carrera Targa
98 F-150 4x4
Old 12-10-2012, 03:14 PM
plumb4u2's Avatar
Beat me
Justin
84 Carrera Targa
98 F-150 4x4
Old 12-10-2012, 03:15 PM
wacko's Avatar
Ok thanks. Just eliminating possibilities. The rubber boot over the connectors is toast, is it worth replacing?
1978 RUF 911SCR
Old 12-10-2012, 03:16 PM
