Air Cooled
Craig_D's Dual Cat SC Exhaust
Hi folks, I've gotten a number of requests for more pics and info about the dual Cat exhaust that I designed and had built for my '78 SC with SSIs. My designs were rough 3D estimates for the idea, but the real person who made it happen is a cage and custom exhaust builder named Hank Padilla. He and his team at Hanksville Hot Rods do great work building cages and exhausts for many Porsches along with tons of other cars/trucks.
The idea that I had (which isn't new, but I wanted to make happen) was that the space between the merge on a pair of SSI headers, and the inputs on a dual in/out Magnaflow style muffler had enough room to squeeze a pair of functional Cats. This way I can pass emissions and run clean all year round. We ended up cutting the SSI headers just after the merge, adding V-band flanges, up-size adapter pipes (from 2" to 2.5"), Magnaflow stainless steel catalytic converters (spun ceramic, 2.5" with straight ends, OBD-II heavy metal), V-band flanges and then an 18" dual in/out Magnaflow muffler. It required a lot of mandrel bends and a lot of patience. In the end, the exhaust passes Colorado emission, is lighter than standard 2 in 1 out sport muffler, and sounds like a German opera sung on the Mulsane straight. Here are pics of the results. Cheers, - Craig_D ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat" - - '99 Honda VFR800Fi, '98 Honda SuperHawk '88 Honda Hawk GT, '77 Honda CB750K Cafe '69 Honda CL350 |
Air Cooled
More Pics:
Air Cooled
Thanks for the pics Craig. I love this exhaust set up. Very clever, looks great and sounds great. A secondary benefit is that the cats are heating your heater air before it enters the heat exchangers.
Truly the nicest concieved exhaust I've seen for the early cars. Great job. If only there was a larger market for it so one of the exhaust suppliers would pick it up to build and sell.
Enjoy the music!
'80 RoW 911 SC non-sunroof coupe in Guards Red It's not a Carrera.... It's a Super Carrera! |
Recreational Mechanic
Wow thats very cool! Nice work!!!
So far the SC passes Colorado Smog every 2 years without the CAT. It just passed again last week under the "fastpass" criteria. The guys who work at the state smog test station have not noticed yet. I think they see the O2 sensor (it's an 82) and assume that the SSI heat exchangers are CATs (or they just look the other way and check it off). Nice to know there is a backup plan for when one of the smog techs finally notices and my SC gets "red flagged" in the state database. ![]()
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing Last edited by Nickshu; 12-13-2012 at 05:59 AM.. |
Diss Member
Did you ever run the car with that muffler but without the cats?
Just wondering how much the cats effect the sound output.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Craig D.,
I must give you great praise simply for your interesting usage of Google/Trimble Shetchup!!!
Daryl G. 1981 911 SC - sold 06/29/12 |
Nice!! That engine is one of the most dry and clean from underneath I've ever seen.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
That is definitely the way to go....and I will end up going that way when my project gets to that stage.
Only question I have is whether anyone is aware of any physically smaller catalytic converters that might tuck in just a little better? Practically I wonder if a converter off of a small car currently in production might work - we only have 1500 cc of exhaust coming into each converter, so a pair of converters off of a 2 litre car should do the trick. I also agree that'd be wonderful for our friends at SSI to do a small fiddle on the primaries to give a bit more clearance for the collector/converter combo - I would imagine that would sell to all us SC or Carrera guys. I know I will grieve when I cut up my brand new SSI's to do this.... Dennis |
Air Cooled
Thanks guys! Yeah Will, I'm getting some extra pre-heating down there.
![]() Nick, it did pass Colorado emissions with no problem, and I'm hoping to pass the fastpass sniffer test so that I don't have to put my damn air pump on EACH YEAR (yes, older than 1981 is every damn year...hence this system ![]() I haven't heard it without the Cats on there, but eventually I'll get Hank to make me some track connectors and remove the Cats for track days. Thanks Daryl, I work for Google and was the first QA engineer hired onto the SketchUp team after they were acquired by Google in 2006. Sadly a lot of my buddies left for Trimble, (I'm still at Google), but I talk to them all the time. Engine is dry/clean only because Colorado is very dry..I didn't clean it. Well, not the bottom anyway. ![]() Dennis, I worked with Hank (at Hanksville Hotrods) for a while on using smaller Cats, and those were the smallest that would actually do the job for the long run. A lot of the smaller Cats can get ruined easily after a short amount of time, and stop flowing (and working). I wanted power for years to come, so that was the way to go. I do scrape them every so often. heh heh - Craig_D
El Duderino
Is it just me or is your sump plate turned 90 deg the wrong way? I thought the drain plug is on the driver's side. At least that's the way mine is on my '83.
As one of the people who was asking questions, I can't wait to look at doing this project! Thanks for sharing, Craig!
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
Senior Member
Yes, that drain plug should be at the "West" (driverside) point - I would look into that and the condition of the bowler-type sump screen for any indents.
But that is one fine-looking exhaust. Nice job!
'78 Targa in Minerva Blue |
Air Cooled
Huh! Well whatdya know?!
I never realized that. I have never personally taken the sump plate off...but I'll look into it. The PO did some screwy things..turns out that I also have a nearly crushed oil return tube from the PO obviously taking the car to a place that lifted the car using the rocker covers (they're crushed as well, but you can't see it unless you're under the car). Since I'm about to do a suspension refresh, and I've decided to shed the rocker covers, I'll be getting new oil lines, so I can also remove the sump plate and rotate it properly. You can even see in my 3D SketchUp mock, that the SSI picture has the sump rotated as you say. Thanks guys!
Mike Ginter
That's nice work. I think I've seen your car at C&C, but it's been a while. Hopefully the weather is decent the first Saturday in January.
Ginter's 914 stuff |
Air Cooled
Hey Ginter, thanks! I made the November C&C and am hoping to be at the January with a completely new suspension, brakes, and oil lines! ...I'll be working my butt off on the rebuild over the holidays, otherwise I'll be in my girl's GTI.
At the last Boulder/Denver C&C, lots of folks came up to say that the exhaust sounded wicked. I went through the gears a bit before turning into the parking lot. I love the way she sounds now! Do you usually bring your red 914-6? I love those...I'd like to have a black wide body 914-6 added to the stable some day. ![]()
Mike Ginter
I was there in November in my zambezi 914. Just got the S two weeks ago last Saturday. I'll bring it January if it's dry out.
Ginter's 914 stuff Last edited by gint; 12-19-2012 at 03:33 PM.. |
Mike Ginter
Air Cooled
Also, I still have the pieces that were cut off and could easily have the V-band flange welded on, to bring the SSI's back to fully stock function. Not that I'm going to do that....I love this system! ![]()
Air Cooled
Sweet!! I hope to see you and the S in January! Even if it's a bust, we'll have to set up a get together with just the Porsche crowd some time!
