Wire in Steering Column (pic)
I'm replacing the turn signal switch. While removing the eight screws that hold the upper and lower steering column covers, I forgot what the wire dangling in the pic below was attached to. Can anyone help refresh my memory? Thanks.
SC
Old 10-23-2010, 12:23 AM
It is grounded onto one of the two top screws
Old 10-23-2010, 12:49 AM
Poor-sche Lover's Avatar
That's weird. On both of mine, it was attached to the bottom right screw.
Alan
Past: '74 914 2.0, '82 911 SC Targa, '88 911 Cabriolet, '88 911 Cabriolet again
Present: '00 Boxster S
"Happiness is not around the next corner......happiness IS the next corner."
Old 10-23-2010, 05:30 AM
Vin-barrett's Avatar
+1
bottom right side screw that holds the plastic cover on also holds this to ground.
-Vinny
1983 911SC
Old 10-23-2010, 05:44 AM
On my 73.5 911T that ground wire is connected to the lower left screw.
Old 10-23-2010, 08:10 AM
Since it's a ground, it doesn't matter, just make sure the wire is not being pulled or chafed.
Old 10-23-2010, 08:49 AM
Wash. State
nesslar's Avatar
Good point. Looks like it has been attached before upper right, and reaching that far would keep it out of the way from the stated chafing, etc.
Old 10-23-2010, 09:35 AM
76 911S Targa
Mine was on the bottom right (76 911S) between the plastic and the metal plate, serving as the ground for the horn. The hard part is getting the little screw through the plastic shroud without the metal ground clip sliding out of the way.
Old 10-23-2010, 10:53 AM
biggtbiggt's Avatar
I just did the same thing as Amanda. Thanks for the post! I put nit on the bottom right.
Have a good day eh!
Old 12-16-2012, 10:55 AM
