-   -   '86 Cab 3.2 still missing/running bad (http://forums.pelicanparts.com/porsche-911-technical-forum/723696-86-cab-3-2-still-missing-running-bad.html)
dcarlson 12-13-2012 07:16 PM
new cap, rotor, wires. Will replace fuel filter then get at the plugs - at least the ones I can reach..(ho, ha.) If that does not cure it I will be in a dark place. Was running a-ok then just started this missing on idle that becomes very apparent when accelerating. http://forums.pelicanparts.com/suppo...oilet_claw.gif
Laneco 12-13-2012 08:22 PM
Probably on the right path, but while you're sorting, on a 3.2 check the tightness of the fasteners that hold the intake to the heads.
angela
Hugh R 12-13-2012 08:46 PM
Run Techron fuel injector cleaner a few tank fulls. Fix mine when I first bought it 9 years ago. It had sat for a while before I bought it.
PatrickB 12-14-2012 01:40 AM
Overhaul the fuel injectors, and it will feel like a factory new motor!
dcarlson 12-14-2012 07:16 PM
has 66,000 miles - could use injectors by now I suppose. Wondering what special tool(s) might help with the plugs on the right side. Nothing too fancy in the tool box right now. Wow. Those Porsche injectors must have some 24K in 'em.
vince_aust 12-15-2012 01:46 AM
I'm with Angela - intake gaskets probably breaking down.
I had the same problem - used a smoke machine to prove intake leaks. Total cost to fix less than $50 but a good 10 hours to remove/replace intake manifold assembly
Vince
Jcslocum 12-15-2012 05:06 AM
The Cylinder Head Temp Sensor is another likely culprit.
Read some here:
http://forums.pelicanparts.com/porsche-911-technical-forum/598996-newbie-car-misses-then-runs-fine-after-warm-up.html
Flat6pac 12-15-2012 06:19 AM
Send the injectors out to Mr Injector, worth every cent which isnt much.
Bruce
rick-l 12-15-2012 08:48 AM
The tool that came in the factory tool kit is the best for removing the plugs.
If you need injectors http://forums.pelicanparts.com/porsche-911-technical-forum/327832-alternative-fuel-injectors.html Go to page 13. I have been running the injectors from Motorman with no issues.
ivangene 12-15-2012 09:20 AM
check for water in the dist cap - if you have been driving in the rain or the car has been in the rain
and all the things listed above, but this one takes 30 seconds
dcarlson 02-26-2013 12:39 PM
thanks for all suggestions - yesterday came across detached vac line that proved to be the culprit. Short 6-8""u-shaped hose that runs from temp sensor at backside of throttle body base and then back to throttle body. Tough to get at but after finally re-attaching it idled rough for 5-10 seconds then settled in to steady idle she always had in the past. Dumb thing I suppose I should have caught earlier but very location makes it hard to notice it until you know the diagram and where to look. thanks again.
