dcarlson's Avatar
'86 Cab 3.2 still missing/running bad
new cap, rotor, wires. Will replace fuel filter then get at the plugs - at least the ones I can reach..(ho, ha.) If that does not cure it I will be in a dark place. Was running a-ok then just started this missing on idle that becomes very apparent when accelerating.
'86 944
'86 911
07 cayman
Old 12-13-2012, 07:16 PM
Laneco's Avatar
Probably on the right path, but while you're sorting, on a 3.2 check the tightness of the fasteners that hold the intake to the heads.
angela
Hello
Old 12-13-2012, 08:22 PM
Detached Member
Hugh R's Avatar
Run Techron fuel injector cleaner a few tank fulls. Fix mine when I first bought it 9 years ago. It had sat for a while before I bought it.
Hugh
Old 12-13-2012, 08:46 PM
Large Registered Member
PatrickB's Avatar
Overhaul the fuel injectors, and it will feel like a factory new motor!
'85 Carrera Coupe, Marble Grey #118 JP/R6
'93 Lexus SC400, '00 Ford F-150
'70 911T- 2.7 (SOLD)
Old 12-14-2012, 01:40 AM
dcarlson's Avatar
has 66,000 miles - could use injectors by now I suppose. Wondering what special tool(s) might help with the plugs on the right side. Nothing too fancy in the tool box right now. Wow. Those Porsche injectors must have some 24K in 'em.
'86 944
'86 911
07 cayman
Old 12-14-2012, 07:16 PM
vince_wa
I'm with Angela - intake gaskets probably breaking down.
I had the same problem - used a smoke machine to prove intake leaks. Total cost to fix less than $50 but a good 10 hours to remove/replace intake manifold assembly
Vince
Garage - 1987 911 widebody
Old 12-15-2012, 01:46 AM
Project Addicted
The Cylinder Head Temp Sensor is another likely culprit.
Read some here:
NewBie-Car misses then runs fine after warm-up
Jon
1966 912
1976 911 3.4 Backdate Project
1986 944
Old 12-15-2012, 05:06 AM
Send the injectors out to Mr Injector, worth every cent which isnt much.
Bruce
Old 12-15-2012, 06:19 AM
The tool that came in the factory tool kit is the best for removing the plugs.
If you need injectors Alternative Fuel Injectors Go to page 13. I have been running the injectors from Motorman with no issues.
Rick
88 Cab
Old 12-15-2012, 08:48 AM
ivangene's Avatar
check for water in the dist cap - if you have been driving in the rain or the car has been in the rain
and all the things listed above, but this one takes 30 seconds
Ed M
86' Coupe
Old 12-15-2012, 09:20 AM
dcarlson's Avatar
thanks for all suggestions - yesterday came across detached vac line that proved to be the culprit. Short 6-8""u-shaped hose that runs from temp sensor at backside of throttle body base and then back to throttle body. Tough to get at but after finally re-attaching it idled rough for 5-10 seconds then settled in to steady idle she always had in the past. Dumb thing I suppose I should have caught earlier but very location makes it hard to notice it until you know the diagram and where to look. thanks again.
'86 944
'86 911
07 cayman
Old 02-26-2013, 12:39 PM
