Mike Ginter
My deck lid keeps popping open
Is there a common failure mode/part and repair?
If I adjust the rubber bump stops in the corners to even out the lid, it pops open on bumps. I can't make it out of the driveway without having to stop, get out and close it. Had to do that 5 times on the way to work today. If I screw in (shorten) the bump stops, the deck lids sticks up on the left side and down on the right. If I gently push down on the left corner to even it out, the latch releases. I'm going to take the spring pin assembly off and clean it up. Is there supposed to be bit of lateral adjustment in that thing? Right to left that is... I suppose it could be bent, but the quick look I had earlier didn't seem like it was.
Ginter's 914 stuff |
the "male" part of the latch on the lid adjusts with a big screwdriver. loosen the locknut first with large pliers. you need to find sweet spot where lid stays closed over bumps but still pops open when you pull the release.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
Mike Ginter
"Male" part.
I get it. Thanks. I'll have a good luck at it when I take it off and clean it up.
Mike Ginter
I expected more of a challenge. All fixed. At least it seems that way for now. I'll find out for sure tomorrow.
Look at the alignment of male & female parts from the back and the side. When that's OK it's just a matter of getting the male part the right length
'81 924 , '85 944 , '78 911SC , '82 928 5.0L "They run best being run close to the ‘limit’ and done so regularly" - Grady |
Caveman Hammer Mechanic
Lube, mine was doing the same thing until I douched it(reciever) with spray white lithium grease.
eric
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
Senior Member
I will guess old gummy grease on latch slide and a lazy cable. Douse and scrub can do wonders. That's what I'd do before adjustment since that is something of a black art!
'78 Targa in Minerva Blue |
It sounds like the male part is to short. Adjust it so you can close with a slight free play. The spring will keep the lid from bouncing around.
Valkyrie |
registered woman user
white 1986 3.2 targa 911 life is what happens while your busy making other plans
Could very well be that the cable stop for the lower (female) part is incorrectly adjusted as well. There is a correct way to set them up, involving a drift through that little hole next to the big one, so that the engaging latch has the proper relationship to the male part (please no jokes here!). The design is carefully intended so that if the cable breaks the latch automatically releases itself. The latched position winds up being in the middle of the full range of travel for the moving piece.
By the way, you do mean a 911 deck lid, and not a 914? Noticed the image next to your user name, and of course 914 engine lids are notorious for doing exactly as you described. |
Funny. After I reread it.:-}
Had the same problem once.
Valkyrie |
Mike Ginter
Thanks for the info all. I'll be doing a drive here shortly to test the adjustment I made last night.
Ginter's 914 stuff Last edited by gint; 12-15-2012 at 10:39 AM.. |
Mike Ginter
My first attempt didn't work. Drove great for about 20 minutes and then started popping up once I got far enough away from home to make a real PITA. Since then I've adjusted the latch/cable tension somewhat and also shortened the pin. It was too long, causing the deck lid to bounce up and down slightly when the bump stops were shortened, allowing travel. Now I have it adjusted so that the bump stops keep tension on the lid, the pin is shortened so that the spring can do its job, and the latch should be in the right position as nearly as I can approximate. Can anyone provide a scan of the procedure for adjusting the latch? All I have is a Haynes book that doesn't describe it in detail. I'll go for another drive today and see how well all of that works out.
I could take some pictures later if that would help. The deck lid latch opening is irritating. The bonnet latch opening is worrisome at speed even though there is a safety catch for that. |
Railroad track crossings are good for testing
Mike Ginter
Looks like I've fixed it! I'd still like to know the actual factory procedure for adjusting that latch.
Mike Ginter
Sometimes it's not the male plunger that needs adjusting, it's the female latch that needs adjusting. In time the latch arm slides open because there's not enough tension on the cable set screw. You need to loosen the set screw, then push the arm "slightly" to the drivers side, hold it in that position, then re-tighten the set screw. At least on my "84" the latch is fail safe since the more the cable slips on the latch arm the less chance the lid will stay closed, i.e. R/R tracks and hard bumps...
Mitch Leland "03" 996 C2S-LS3 V8-480 HP "84" 911 Turbo Look-Sold w/ found memories |
Popping open is the rare check your oil level reminder option..
Mike Ginter
I've checked oil on this thing over and over again. It doesn't ever change.
