-   -   Engine running temperature (http://forums.pelicanparts.com/porsche-911-technical-forum/723845-engine-running-temperature.html)
maui44 12-14-2012 08:07 PM
For those of you that have a temperature gauge in your cars, what is the freeway temperature show when it's say 70F outside? My car is a stock 2.7.
Thanks in advance for your replies
drtyler 12-14-2012 08:17 PM
180 - 200 degrees F
My car is a 1975 with 2.7 and oil cooler in front right fender.
manbridge 74 12-14-2012 08:49 PM
^^ Same as the good Doc but a 74 non-S.
redstrosekNic 12-14-2012 09:44 PM
Around the 190*F range for the given conditions.
Joe Bob 12-14-2012 10:07 PM
Drop yer head to the right of the steering wheel....look left under the bezel of the temp gauge...you'll see little numbers, in Centigrade. There are a few threads with pics on the board that a search will find.
There are also little overlays that you can purchase. Or you can just watch when the needle stops rising and then dips abit....that's about 180-190F....when the thermostat opens.
edit: Here's the numbers......
http://forums.pelicanparts.com/uploa...1186020743.jpg
105C in the exact middle = 221F
C = (F - 32) × 5/9
quattrorunner 12-14-2012 10:10 PM
This is a really incomplete question but I know what your after and I ave many answers. For 70 degree day
1) 1977 911 no aux cooler up front= around 200f for my car
2) 1977 911 with turbo and cooler in fender = about 210-225f
3) 1977 911 with turbo and cooler in fender and duct in valance = 190-210f
4) 1977 911 with turbo and cooler in both fenders and duct in valance for both= 180 max on 70 degree day on the freeway never more. Maybe 210 degrees at over 100 mph all day long.
But...... The reason for more coolers for me is:
1) Vegas heat
2) long summers and traffic.
3) expensive engine I don't like to cook in Vegas heat.
Hope I helped.
redstrosekNic 12-15-2012 07:18 AM
You should make sure your gauge isn't off. I posted a similar video to this a while ago, but this one is of better video quality, and the stove in this video made a pot of water boil much faster than the POS hotplate in the old one.
Porsche 911 oil temp gauge and sender test - YouTube
maui44 12-15-2012 06:06 PM
Thank you everyone for providing the numbers. We all are running about the same temperature which is cool (no pun intended). It was just a basic question. I was not looking for any "it-then" calculations.
Thanks again,
mreid 12-15-2012 06:13 PM
My 1986 930 runs at 180 consistently and has an additional oil cooler in the front valance.
maui44 12-15-2012 06:36 PM
Thank you everyone for the numbers. We are all running about the same temperature which is cool (no pun intended). I was not looking for any "if-then" . Just basic feedback which everyone provided.
Thanks again
