SSI/Header Engine tin
Gentlemen
Can anyone confirm the p/n pls for the LHS engine tin for those cars fitted with SSIs or headers? I've managed to order the wrong item - looks correct for a MFI car - #6 on this page (p/n 90110608304) LINKY I believe it should be parts #5 and #8 (first one) on the above page ? 90110608302 - engine tin long 90110682500 - engine tin square with hole For reference, the RHS parts i've ordered which look correct are: 90110608400 - RHS engine tin Long 90110682600 - RHS enginer tin Square |
Parts 5 and 8 on your referenced page are the right hand eng. tin pieces. The left hand tin you seem to want is circled below and has a part no. of 901.106.083.02 (from factory parts manual). The small heat tube indicates it fits an MFI engine. http://forums.pelicanparts.com/uploa...1355637585.jpg There should be another version of that part w/o the heat transfer tube (for non-MFI engines). However, that number isn't listed in my doc. The left side square piece with provision for heater hose pass-through is 901.106.825.00. This link has a couple of sellers for 901.106.083.02; RICK RAES and tom1394racing. http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/722644-engine-tin-wanted.html#post7136396 Hope this helps, Sherwood |
Thanks for the input
Pretty certain 5 and 8 are the LHS items in my diagram, just not correct for my car - 7 and 9 in mine are the RHS tin pieces and are the equivalent of your 26 and 29 Correct - I'm looking for the non-MFI LHS tinware item - both the 90110608302 and 90110608304 (which i've just purchased) are MFI items. |
Quick bump as i'm still unsure and these parts aren't returnable so don't want to make the same mistake
Any 3.2 owners running ssi/header with the hose running though the LHS tinware, care to confirm part numbers? 90110682500 - square part for hose pass through 91110608301 - long LHS tin Unsure if the 2 are compatible and correct for a 3.2 Thanks |
Here's my planned heat conversion for a 3.2, almost ready for refinishing. Engine tin marked with the letter "E" identify parts from an early 911 (<73). To ID part numbers, match this photo with the factory exploded parts illustration from a previous post. YMMV as to adequate heated air for your operating conditions. Obviously, more volume with a forced air blower motor.
http://forums.pelicanparts.com/uploa...1356593874.jpg Notes: E1 from later 911s have a large hole for the hose from the engine-mounted blower motor. The hole can be blocked instead of using this early engine tin. E3 provides an air path to the SSI/factory HEs from E2. It's a mirror copy of the passenger side tin (not interchangeable) E4 will need a hole for the O2 Sensor harness and grommet. Sherwood |
yeah,Quick bump as i'm still unsure and these parts aren't returnable so don't want to make the same mistake.thank youhttp://www.okhealthy.com/youjie/images/5.gif
Are there any markings on your 'E4' part? Could you measure the length of that E4 pls? I have the E1 part you describe on my 87 yr car - will continue to use that as I have partially backdated heat |
Here's another method. The length of the factory 3.2 version of E4 includes the dimension of E3. Thus, measure the current E4, then subtract the dimension of the pass. side hose guide, the opposite version of E3. The difference is the length of the early version of E4 (less the overlapped metal to assemble the pieces). A third method: E4 spans the distance between the front (forward) end of the cam housing to the chain box cover. Hope this helps. Let me know if you need a more exact measurement. Sherwood |
to close this out - the p/ns below correlate to Sherwood's pic above (E3 and E4)
90110682500 - square part for hose pass through 91110608301 - long LHS tin Thanks for your help Sherwood |
| All times are GMT -8. The time now is 09:05 AM. |
