michaelw's Avatar
Uugh, electrical problems...
Rather ubruptly, my 87 3.2 has developed an electrical problem. The 2 year old battery which has never once had a problem, now will not start the car. I had the alternator redone last summer as the alternator light started pulsing, but since then no problems.
First the alternator does not illuminate once the car is running (from a jumped start) and is registering 12.95V while checking across the battery. Before the start it was reading 12.00V. I checked the following morning and the battery read 11.87V and this afternoon at 11.85V. What's up? If it's draining, it's draining very slowly.
Thanks,
Michael
Old 06-24-2002, 12:42 PM
CamB's Avatar
Batteries sometimes don't last very long (in my chequered experience with them).
12.00v is pretty dead (should be 12.5 ish). I you have a charger you should give it a full recharge and see if it holds it.
12.95v when car is running is too low an output for the alternator as well (should be 14.4ish). I think you might need to get the alternator and regulator checked (and may need a new battery too).
1975 911S (in bits)
1969 911T (goes, but need fettling)
1973 BMW 2002tii (in bits, now with turbo)
Old 06-24-2002, 03:56 PM
Battery load test
If you take your battery to a shop to load test it, make sure that it is fully charged before testing. Testing is done with a VAT (voltage-ampere test). The amount of load is based on the amp-hour rating or the cold-cranking amp rating. The battery is loaded at 3 times the amp-hour rating or 1/2 of the cold-cranking amps for 15 seconds. Battery voltage should be at least 9.6 volts. HTH.
Old 06-24-2002, 04:09 PM
Banned
dood
while the car is running test the voltage between the positive and neg batt terminals,, then check it between the pos terminal and a frame ground or some other good ground. i just did the same thing to a car yesterday and all it was,, was a bad ground strap.
I hope that helps you!!
LATE-ER
Kyle
71 911
Old 06-24-2002, 06:12 PM
michaelw's Avatar
Thanks - guys! Will definitely try to the ground strap test.
Michael
Old 06-25-2002, 03:04 AM
