VADER 935
Brakes, please help!
Hi all, I'm building a Porsche 911 race car from an 86 3,2 Carrera and I need to change the brakes. I have on the shelf a pair of 930 turbo front Calipers and a pair of 993 black rear calipers, Would the bias be acceptable on piston size etc once the conversion is done. I understand that I may need to run 930 rotors front and back, or di I. I've need seen this odd combination before, would it work guys??
Old 12-19-2012, 01:52 PM
Bill Verburg's Avatar
930/993 on 930 rotors is a little more than usual rear bias, worse comes to worse put an adjustable pressure valve on the rear circuit
Bill Verburg
Old 12-19-2012, 02:00 PM
VADER 935
Great, thanks for the quick response Bill, just what I wanted to hear.
Old 12-19-2012, 02:49 PM
ivangene's Avatar
Bill knows his brakes - and knows mine - he has helped many of us
Ed M
86' Coupe
Old 12-19-2012, 03:11 PM
Grand Am/IMSA Data Guy
Porsche84's Avatar
Swap out your master cylinder to the turbo one. You'll need to push more volume to operate the bigger calipers. I run big red fronts (993 TT) on the front and 944T front calipers on the rear with 930 rear rotors. The balance is really good. I bought a proportioning valve but have not installed because I like the balance. My car is an 84 911 and weighs 2250.
Jerry Austin
AIM Data Products Dealer
84 911 3.6 track car - Sold
Morris Minor Van with S2000 running gear
http://austinmotorsportsllc.com/
Old 12-19-2012, 03:38 PM
certainly you need a 23.8mm m/c, the 930 is a bolt in for you
Jerry certainly has way more rear bias then is normal
here are some #S for comparison brake torque in N @70bar line pressure
stock '86
w/o the stock 33bar p/v 1444/1183 for a ratio of 1.2
w/ the stock 33bar p/v 1444/639 for a ratio of 2.26
'74 2.7RS
1444/969 for a ratio of 1.491
930 front 993 rear all on 930 rotors
w/o the stock 33bar p/v 1961/1242 for a ratio of 1.382
w/ the stock 33bar p/v 1961/766 for a ratio of 2.56
993RS w/abs
w/o the stock 55bar p/v's 2306/1618 for a ratio of 1.426
w/ the stock 55bar p/v's 2306/874 for a ratio of 2.64
Jerry's 993tt/944f
w/o a p/v 2306/2230 for a ratio of 1.034
the lower the ratio the lower/stiffer the car needs to be and the effective the lsd needs to be on decel
Bill Verburg
Last edited by Bill Verburg; 12-19-2012 at 04:22 PM.. Reason: correction of a typo
Old 12-19-2012, 04:07 PM
Porsche84's Avatar
Wow, good info Bill. Did you calculate my fronts using 993 TT front rotors? Maybe I do need to install the bias valve and see the difference.
Jerry Austin
Old 12-19-2012, 04:29 PM
Racer
winders's Avatar
Hey Jerry, I see you have your race car setup with a near 1:1 bias ratio just like my race car. I kept thinking about getting a pedal cluster and making my own 911SC/RS style dual master cylinder setup. But my brake bias is damn near perfect on the track so I didn't follow through with it. It's good to see that "California physics" work in Florida too. Maybe the state needs to grow a lot of oranges for that bias ratio to work.
Scott
Old 12-19-2012, 04:39 PM
Racer
winders's Avatar
Why? Are you rear brakes locking up on you when your fronts don't? Are you inducing oversteer on braking?
Scott
Old 12-19-2012, 04:42 PM
Porsche84's Avatar
Scott, glad to hear. Come to Florida and we can compare at Sebring
Jerry Austin
Old 12-19-2012, 04:43 PM
Racer
winders's Avatar
I would love to, but traveling to Sebring just isn't in the race budget. Even if it were, my race is built for a particular Porsche Racing Club (PRC) class. The car would be in PCA GT3 but the engine is way under developed under GT3 rules.
Have fun!
Scott
Old 12-19-2012, 04:47 PM
VADER 935
Ok Bill, great info, a few more answers on this please.
You mentioned a 23.8 mm M/C, Is this a kit to fit the 993 calipers to stock 3.2 trailing arms, If so where do I get it from?
Can the 993 calipers be ran on stock size 3.2 carrera rotors
I understand that 930 rotors will push the wheels out 22mm is there another rotor option for my application to avoid this ?
Thanks for the info so far
Paul.
Old 12-20-2012, 02:02 AM
yes
just for comparison here's a 2007 GT3 RSR w/ twin masters, it's not directly comparable to the ones above because I used 50 bar as the front line pressure
Porsche base setting
4545/2818 ratio 1.613
balance all the way front
4545/2367 ratio 1.920
balance all the way back
4545/3607 ratio 1.260
Bill Verburg
Old 12-20-2012, 05:36 AM
Paul.
if you use the late('81up) front hubs and rotor then yes the frot wheels are pushed outboard and you need to use 930 front fenders
if you use '78/79 hubs which are the same as 911 hubs '69-89 and the '78/79 flat hat then no the wheels stay the same as on a 911 w/ stock brakes
do use 930 rear rotors, you will have to discard the stone shield and slightly modify the 993 rear caliper in 2 ways, first the stock mounting holes are filled w/ a plug then new holes are drilled slightly lower to fit the caliper to the rotor. Second mod is to grind the throat area a little wider, if you use 965 rear calipers this second step is omitted. I would still prefer and urge that 930 rears be used. It seems that I see them frequently in the for sale section
Bill Verburg
Old 12-20-2012, 05:43 AM
