bcheney's Avatar
Window trim and seal 89 Targa
I have a 1989 3.2 Targa. I need to install new window seals (The seal that runs along the bottom outside of the driver and passenger side glass). What is the best way to remove the old rubber seal from the aluminum trim and reinstall the new seals? The Bentley manual does not shed any light on this and I haven't been able to find any information in this forum.
Thanks,
Brian
08 Cayenne V6
89 911 Targa Carrera 3.2
75 914-6 Conversion
Old 10-28-2011, 09:13 PM
Weekend Mechanic
vulcan300's Avatar
If you're referring to the rubber squeegee you can gently pry underneath aluminum strip and it will pull up. The strip is held in place with small spring clips that create a press fit. Once pried up you can slide the old seal off and slide the new one on. A little spray silicone or soapy water will help get the seal to slide into place smoothly.
86 911 Carrera Targa
Old 10-29-2011, 02:26 AM
bcheney's Avatar
Finished
Thanks for the info. I was able to get them installed today. I snapped a shot of how the trim and seal work for anyone's future reference. Trims raises up without a problem with a smooth flat edge. I used liquid soap to lubricate the seals before sliding them into the trim.
08 Cayenne V6
75 914-6 Conversion
Old 10-29-2011, 02:56 PM
muck-raker
kidrock's Avatar
Oh, great....now I have another project in front of me.
Glad to see it was such an easy fix.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 10-29-2011, 08:02 PM
Reviving and old thread
Does the chrome trim on my 71 Targa pop out the same way so I can slide the new rubber squeegee in? There is a piece in the way at the open end of the door that makes sliding it in as it sits on the car difficult to do without damaging the squeegee.
1971 Light Ivory 911T - Gretchen - sold
Looking for Engine # 6114097
2010 Cayman
Old 12-18-2012, 06:53 PM
