Banned
what yr is this grill from?
can anyone tell me what year this grill is from? its obviously sprayed black. also how could this be cleaned off without damaging it? also what may be value on this either as is or with being cleaned up?? tia
Old 12-17-2012, 11:34 AM
Looks like the same grill as on my '74
Old 12-17-2012, 11:57 AM
Banned
yes, i thought it was like a 73.5 i had as a parts car. what threw me off is the black paint that was flaking and aluminum underneath. what did a 70 71 or 72 look like up close?
are these worth 300.?
Old 12-17-2012, 12:04 PM
I'm not sure about the earlier cars but on my '74, it was originally annodized black but that has worn off and is now a silver/purple color. Some people paint them - I plan to have mine re-annodized someday.
Old 12-17-2012, 12:10 PM
AutoBahned
RWebb's Avatar
looks earlier than '74 - not sure exactly when as those toes made me quickly avert my gaze
is it metal or plastic?
Old 12-17-2012, 12:30 PM
Banned
It's metal. Someone else said it was 70 / 71 and that makes a lol more sense cause the engine is a 70t engine. The thing that I kept looking at was after the black paint flakes I see alum silver underneath. The 73 74 is anodized black which is not there. Anyone got any 70 71 grills I can see?
Old 12-17-2012, 04:01 PM
My 69. I believe they changed to black in 73.
69 911 2.3Ez
85 928S
Old 12-17-2012, 05:23 PM
That style grill came out midyear 1967 when the decklid changed to one bigger opening from the previous two openings. It was not black anodized until late 1972 or so.
I've taken those completely apart before. Each individual rail can come off.
Current: 914/6 GT Conversion, Cayman
Old: Many PCars + Formula Racecars
Old 12-17-2012, 05:26 PM
If you remove each rail, you can clean it up fairly well with a soft steel wool and a bit of paint remover (IF it is paint!)
Old 12-17-2012, 05:28 PM
Banned
gee, thanks for the great info. whats one of these worth BOTH in as is and then cleaned up prices?
Old 12-17-2012, 07:05 PM
Shaun @ Tru6's Avatar
There are 4 distinct grills for 65 to 73 911s. Sorry for the bad pics.
65 to 68 1/2 used this type of grill with the split decklid
68 1/2 to 69 got a new style grill marked by having only 3 bars. these don't have studs but use cheesehead bolts. decklids are also unique to these years, though any other lid will fit.
70 and 71 got the same clear anodized grill but Porsche added 2 bars, almost certainly because the 3 bar grills deforme so easily. decklid added 4 bumps to match up to the 2 new bars.
72 to 74 got black anodized grills, though this one looks like it was rattle-canned.
Tru6 Restoration & Design
Old 12-17-2012, 07:31 PM
Banned
Thx again. That's exactly what I hoped for.
Old 12-18-2012, 05:27 AM
tobluforu's Avatar
Which one of those four is worth the most?
Old 12-18-2012, 06:22 AM
My sense is the 68.5 to 69 3-bar grill is worth the most in excellent condition. These go for $400 to $500 for the one shown above.
Old 12-18-2012, 06:40 AM
Thanks Shaun for the updates and pictures. The 1965 to 1967 (build year) grills are more "ornamental" and intricate.
Old 12-18-2012, 08:25 AM
I remember when I learned the 3-bar grill wasn't 69-only but started late in 68. I love all the details and changes on these cars over the years, and what amazingly stayed the same.
Old 12-18-2012, 10:10 AM
I had two late 1968 cars with the 3 bar grill. Problem is I had so many early cars I mix them all up now! The 1965 build 911 I had was my favorite. The valve guides had worn out at 70K, so I put my 70S engine in the thing at the time. Fun.
Old 12-18-2012, 11:43 AM
Engine Grill
My car is a 74 and its grill looked pretty bad too. Yours is somewhere between 69 and 76. Mine was anodized black and had faded to purple. I spent a lot of time on it with oven cleaner (a fellow on Pelican recommended oven cleaner - just be careful, cause the fumes are bad) (used a whole can or more), paint stripper, steel wool, etc. First i ground off the rivets and took the mesh off of the back. Do it carefully so as to not destroy some rubber strips that hold the top and bottom edge in place. Once I had the anodized material off, I sanded and polished the top edge of the ribs, brush painted the 'straps' and sprayed the mesh. Then reassembled.
A lot of work, but what else would I do on a rainy Sunday?
I don't always talk to liberal arts grads, but when I do, I tell them Big Mac and small fries!
1974 911 RUF Clone ('85 3.2; '86 915)
1974 914 ('87 3.2L & 915 transaxle)
2005 Boxster (Base car) Guards Red.
Old 12-18-2012, 01:22 PM
Banned
I'm doing a backdate 72 starting with black brightwork to an alum look so rear grill is a big part of this look. Looks like I'm polishing one of mine. Thx.
Old 12-18-2012, 02:53 PM
grill
vintage. I agree with the bright trim needing a polished grill. This is the car I am building. I think the tail lights are going to be european (all clear) with bright edges.
Old 12-18-2012, 03:03 PM
