aseem's Avatar
Any excperience with circuit breakers in cars
After numerous startup problems with a root cause in the fuse box, with a melted or blown fuel pump fuse, I'm looking at the D-Zug fuse box utilizing ATO type fuses.
They also mention support circuit breakers on their web site, so I found these manual and automatic breakers:
Narva Blade Automatic Circuit Breaker - 10 Amp
Circuit Breaker | Narva Blade Manual Circuit Breaker - 20 Amp
I didn't know stuff like this existed for cars, so I'm curious if there is any first hand experience with circuit breakers in cars?
Arnljot
1980 930 GT35R, TurboKraft IC, 965 P&C, 964 Cams, Tial WG, ported heads, BLWUR, RarlyL8 hdrs&mfflr, Zeitronix logger & wideband
1989 928GT
1972 BMW 3.0S
Old 12-24-2012, 02:38 PM
i see those sometimes in cars as factory equipment. but if your blowing fuses there is a reason.
Old 12-24-2012, 03:55 PM
aseem's Avatar
The problem is mostly that things get hot due to small contact surfaces and oxydation. By upgrading to D-Zug Fusa box, I can use ATO fuses, or circuit brakers, bit sine I have no experience with circuit brakers I wanted to ask the crowd here at PP.
Arnljot
1989 928GT
1972 BMW 3.0S
Old 12-24-2012, 05:03 PM
ROW '78 911 Targa
timmy2's Avatar
Fred Cook one of the members here makes those fuse panels. Must be re-selling at D-Zug.
Here's a link to Fred's post.:
New ATO Fuse Panels....
$20 breaker or a $2 fuse, it's up to you. They both provide the same protection. One can be re-set, the other needs to be replaced. If you're blowing ATO fuses you have other problems.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 12-24-2012, 05:18 PM
nineball's Avatar
we use them all the time in audio installations however the smallest one we usually use is 150a. makes it much, much easier to swap out components simply by flipping the breaker.
Car Circuit Breakers at Sonic Electronix
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 12-25-2012, 07:57 PM
T77911S's Avatar
circuit breakers are used onelectric windows or power seats. they can draw too much current at times and the circuit breaker just resets.
i would not use them anywhere else. if things like lights and radios are blowing fuses, no matter what type, there is a reason. just fix it. if you have added lights or a big power amp, the wiring to these tings needs to be upgraded to wire big enough for the load.
fuses are not in there to protect radios and lights, they are there to protect the wiring from too much current. put enough current through any wire and it turns into a light bulb, just before it catches fire.
the 911 fuse box can be made to work. i removed each fuse one at time and cleaned the fuse contacts, removed the wire to the fuse, cleaned the wire and the screw that clamps the wire.
youcould replace all fuses, i just cleaned them. i did this for each fuse.
resistance builds up heat and causes voltage drops. keep things clean.
i did auto electric work for a living for a short while and have been an electronics tech for over 20 years
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 12-26-2012, 04:27 AM
