Car nerd
green912's Avatar
88 911 with G50 hard to shift when cold
Ok, so I know that I probably will have to replace the gearbox oil, but I want to know what other people have done.
My first winter with my 88 911 G50 LSD and the first couple of shifts in the morning and I have to leave extra time with clutch in to ensure a clunk-free gear change.
This "propensity to clunk" lasts for about a mile or two on my commute and then the gearbox oil is "moving freely" and shifts like butter as normal.
I've heard that swepco is good, and I would like other's advice on fluid used.
I really appreciate the knowledge base here and I want to be a good custodian of this car because it is very important to me personally.
The previous owner was a WWII veteran and passed at 94. The opportunity to own his 911 was not one I was going to pass on.
I have checked the gearbox oil level and it is as it should be.
THanks and I look forward to your suggestions.
Kevin
1966 Irish Green 912
1988 Dark Blue 911 Sunroof Coupe
Old 12-13-2012, 06:48 AM
Easily Confused
dtxscott's Avatar
Swepco is better for the 915.
For the G50, Mobil Delvac has worked for me. It fixed the cold morning clunks.
Scott C.
'08 Cayenne GTS 6MT : '89 Targa GP White/Black - "Oliver's Car" : '11 Mitsu Evo X : '08 Lexus IS350 F-Sport : '01 Toyota Sequoia : 1998 Yamaha V-max : 1979 BMW R65
Old 12-13-2012, 06:54 AM
OffCamber00's Avatar
Redline 75W90. Use the "NS" if you don't have an LSD.
I have used this in my 88 for years and it works very well.
Mat P
1988 911 Carrera
Old 12-13-2012, 07:08 AM
On Tour
MMiller's Avatar
I also use the Mobil 1 product..
However when cold my G50 is "a little stiff" in 1st and 2nd until it gets warm. This is true for summer or winter.
Mike
- 2018 Cayenne S 958.2
- 1988 Carrera 3.2 Coupe Marine Blue (SOLD)
Car nerd
green912's Avatar
Any chance the wise ones can tell me how many quarts, I'm on the road and don't have much time to drill down and research how many quarts for the G50 with LSD.
thanks
Kevin
Old 12-13-2012, 07:11 AM
Northern Motorhead
wildcat077's Avatar
My 89 G50 is hard to shift as well until it warms up.As far as oil quantity goes,i usually purchase 4 liters at each gearbox oil drain or when i drop the engine and i have some left over ...
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 12-13-2012, 07:15 AM
Gear oil volume........
thanks
Kevin
green,
A gallon (less than 4 quarts) of gear would be sufficient and you would actually need around 3.5 liters to refill. Last month when I did a gear oil change, I was having difficulty getting Mobil Delvac gear oil and ended up going to the local Porsche dealership. It turned out that they didn't sell gear oil at the parts department but was willing to give me some.
Tony
Old 12-13-2012, 07:48 AM
Quantum Mechanic
mpetry's Avatar
Send a message via Yahoo to mpetry Send a message via Skype™ to mpetry
Since nobody else mentioned it - make sure your clutch is bled. The G50 has a hydraulic clutch - if it is not releasing fully you can get a resistance and clunk sound when shifting.
Mark Petry
Bainbridge Island, WA
81 SC
Old 12-13-2012, 07:57 AM
As others have said, stiffness from first to second when cold is normal. It's there even when I double-clutch.
The clunking might be something more, however, but I'm not sure. Do you get it with any of the other shifts, second to third, third to fourth, etc.?
Old 12-13-2012, 08:25 AM
Did you get the memo?
onewhippedpuppy's Avatar
The mechanic that rebuilt my engine, installed a shortened 5th gear, and installed my LSD recommended Amsoil 75w/90 for the G50. He said he's normally not a member of the Amsoil cult but that their gear oil is very good. I haven't changed mine yet, it's on the to-do list.
I won't worry too much about slow and notchy when cold. I'm yet to drive a manual gearbox car in the winter that wasn't a bit clunky until warming up.
‘07 Mazda RX8-8
Old 12-13-2012, 08:47 AM
Justin@Athens's Avatar
Send a message via AIM to Justin@Athens
Kendall, also Brad Penn makes a 75-90w tranny fluid.
1990 964 C4 Coupe & 1991 964 C2 Coupe (current)
1989 911 Targa (sold)
1996 993 Cab. (sold)
1999 x2 Boxster (sold)
2006 Cayman S (my daily)
Old 12-13-2012, 08:58 AM
my '87 shifted hard 1st/2nd with swepco, 1st thing in the morning. a kendall swap made a noticeable difference. it's not just for earlier syncros.
206 637 4071
Old 12-13-2012, 12:17 PM
+ 1 for the Mobil Delvac it worked well for me.
Old 12-13-2012, 12:26 PM
I've tried several including Mobil, Amsoil, and Redline, and have just learned to live with a 1-2 "knotchy" shift when she's cold. I '"baby" her on the first couple of shifts, and when it's REALLY cold, I'll pause in neutral and double clutch for the first couple of times ...works for me. I only have issues from 1st to 2nd and it disappears before I'm out of the 'hood...nature of the beast .
Old 12-13-2012, 01:47 PM
+1. On redline n/s. for non limited slip g50. Shifts great cold or hot.
Old 12-13-2012, 08:23 PM
Car nerd
green912's Avatar
well that was nice of them!
Old 12-14-2012, 04:37 PM
Car nerd
green912's Avatar
Thanks, I will check that too.
Old 12-14-2012, 04:38 PM
Car nerd
green912's Avatar
Has anyone tried the fully synthetic royal purple gear oil in the G50? Is it OK with the LSD?
Old 12-23-2012, 03:32 PM
Old 12-23-2012, 06:19 PM
mystro's Avatar
I am running Royal Purple in everything now. My tranny shifts like new even in the (28 degree) cold. I have used Amsoil in all my other toys but now I am all Royal Purple.
Old 12-23-2012, 06:41 PM
