Roslin's Avatar
8/9x16 Fuchs - comb. w. 930 brakes on SC
I'm thinking about buying a set of 8" and 9"x16" Fuchs wheels 951.362.117.00 and 930.362.119.00 (944 Turbo rear's and 930 rear's)
Is it possible to combine these wheels with the 78 on 930 brakes on a car with std. SC /Carrera flares ?
Can i use std. rear trailing arms without getting clearance problems between wheel and caliper ?
Can i go with std. hubs in the front, with these brakes/calipers without spacing the wheel
- if not - how much do i need ?
Thanks in advance !
Porsche 911 SC 3.0
Old 12-30-2012, 01:17 PM
jsveb's Avatar
Thats what I got n my Carrera 3.0
I had no problems when mounting them.
Jesper
Carrera 3.0 1975
930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer
www.stauningwhisky.dk
Old 12-30-2012, 02:12 PM
Bill Verburg's Avatar
yes, the front will be extremely tight to the fender lips as the o/s of the wheels is a bit less than ideal. The front 8 you are considering has an ET 23.3 I use 8 ET25 which is tight, 8 ET30 is much preferred
Can i use std. rear trailing arms without spacers getting clearance problems between wheel and caliper ?
yes, no problem in back at all.
yes, In fact you have to use standard or equivalent low o/s hubs. The late 930 hubs will o/s the wheels too far outboard. Along w/ the std 911 hubs you will need a flat(0 o/s) rotor adapter(hat)
You can use oe '89-80 930 floating 304x32 hat and rotor assembly on std 911 hubs or an aftermarket flat hat on aftermarket 304x32 rotors
the front will look like this
911 hub, flat no floating hat aftermarket 304x32mm annulus
Bill Verburg
Old 12-30-2012, 02:15 PM
ShakinJoe's Avatar
Yes yes and yes.
This is one of best set ups in my opinion. You can even use 993 brakes on this set up.
'87 Carrera - 2400 lbs of Track Beast!!
'88 Carrera Cab - Too nice for the track.
'85 Targa - Salvage title that was not caught!
Old 12-30-2012, 02:16 PM
Roslin's Avatar
Bill, Thank your for nice detailed feedback.
My main concern was if the caliper bodies would clear in between the outer disc surface and the back side of the 951 wheel, but maybe your small adaptor make the clearance ?
Porsche 911 SC 3.0
Old 12-30-2012, 02:36 PM
Roslin's Avatar
Jesper, Do you have some pictures of your setup ?
Porsche 911 SC 3.0
Old 12-30-2012, 02:41 PM
don911's Avatar
951 7s will also work up front. My street wheels are 951 7s and 8s. You may want to look at tire options before going with these wheels. Street tires for 9s are getting hard to find....at least in the states.
Don
24 Cayman GTS - GT Silver
23 Cayman GTS - Arctic Grey - Sold
97 993 Coupe - Arctic/Black - Sold
13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue
Old 12-30-2012, 02:56 PM
Roslin's Avatar
This is the immediate search i did on the size for the 9's I have also seen a Michelin tire in that size.
Continental SportContact 245/45 ZR16
Bridgestone Potenza S-02 245/45 ZR16
Porsche 911 SC 3.0
Old 12-30-2012, 03:10 PM
