8/9x16 Fuchs - comb. w. 930 brakes on SC
I'm thinking about buying a set of 8" and 9"x16" Fuchs wheels 951.362.117.00 and 930.362.119.00 (944 Turbo rear's and 930 rear's)
Is it possible to combine these wheels with the 78 on 930 brakes on a car with std. SC /Carrera flares ? Can i use std. rear trailing arms without getting clearance problems between wheel and caliper ? Can i go with std. hubs in the front, with these brakes/calipers without spacing the wheel - if not - how much do i need ? Thanks in advance !
Porsche 911 SC 3.0 Last edited by Roslin; 12-30-2012 at 04:16 PM.. |
Thats what I got n my Carrera 3.0
I had no problems when mounting them.
Jesper Carrera 3.0 1975 930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer www.stauningwhisky.dk |
You can use oe '89-80 930 floating 304x32 hat and rotor assembly on std 911 hubs or an aftermarket flat hat on aftermarket 304x32 rotors the front will look like this 911 hub, flat no floating hat aftermarket 304x32mm annulus
Yes yes and yes.
This is one of best set ups in my opinion. You can even use 993 brakes on this set up.
'87 Carrera - 2400 lbs of Track Beast!! '88 Carrera Cab - Too nice for the track. '85 Targa - Salvage title that was not caught! |
Bill, Thank your for nice detailed feedback.
My main concern was if the caliper bodies would clear in between the outer disc surface and the back side of the 951 wheel, but maybe your small adaptor make the clearance ?
Porsche 911 SC 3.0 |
Jesper, Do you have some pictures of your setup ?
951 7s will also work up front. My street wheels are 951 7s and 8s. You may want to look at tire options before going with these wheels. Street tires for 9s are getting hard to find....at least in the states.
Don 24 Cayman GTS - GT Silver 23 Cayman GTS - Arctic Grey - Sold 97 993 Coupe - Arctic/Black - Sold 13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue |
This is the immediate search i did on the size for the 9's I have also seen a Michelin tire in that size.
Continental SportContact 245/45 ZR16 Bridgestone Potenza S-02 245/45 ZR16
