French Import
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
PMB Performance
Pretty sure "Havana Machine" is a massage parlor in the Denver area. Clever how it shows up on the credit card statement. "No honey... they packed my bearings for me!"
Eric Shea - PMB Performance 855-STOP-101 We Restore Vintage Calipers www.pmbperformance.com |
Air Cooled
LOL! $45 for monoballed banana arm?!
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat" - - '99 Honda VFR800Fi, '98 Honda SuperHawk '88 Honda Hawk GT, '77 Honda CB750K Cafe '69 Honda CL350 |
Recreational Mechanic
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing |
Mike Ginter
I like to pack my bearings by hand. :P
Ginter's 914 stuff |
Air Cooled
Out with the old, in with the new Red Line CV-2
Another late night...seems after-work time slips away quickly what with daily life stuff.
So, last night I pulled the left side hub and cleaned the bearing of all the Lithium grease. Here's how I did it. First, clean rags. Then, Q-tips and tooth picks to get the large bits out. Next, WD-40 sprayed into the bearings. Then, air compressor gun and clean rags. Worked like a charm. The only snag was that I...ran outta freakin grease before finishing the second bearing!! GRRR! You see, the night before, I did a bone-head move with my fresh Red Line grease. I was purging the grease gun tube of the lithium grease and ran into an air bubble. So I lost pressure in the gun. Well I couldn't get the air release valve to work, so instead I pulled the canister off the head...except I forgot to de-pressurize the rod...SO, almost all of the grease crapped out right onto my work bench! FAAAAARK! I counted to 10, and then luckily realized that the grease pooped out onto a fresh shop towel. So, I scooped up the grease in my gloved hand and pushed it back into the gun. But I lost a bunch...so, between that, and purging the lithium, I didn't have enough to finish the outer bearing. I have another tube on the way, and I'll have to finish this weekend. Oh, here's a tip. If you need to get a freshly installed dust seal out of the rear of the hub, use a PVC pipe and gently tap it through the hub (from the front) with a rubber mallet. This removed it with no damage. Cleaning it out required removing the spring ring from inside the rubber seal...it was easy enough, but time consuming. Here are the pics.. Old grease (shot Horror Movie style!!) ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat" - - '99 Honda VFR800Fi, '98 Honda SuperHawk '88 Honda Hawk GT, '77 Honda CB750K Cafe '69 Honda CL350 Last edited by Craig_D; 02-14-2013 at 07:40 AM.. |
AutoBahned
Air Cooled
Yeah, I made sure they didn't spin. I had a rag in my hand, with the bearing in the rag and shot down into the top of the gap. I shot the grease out towards the bottom and sides, but nothing spun. Plus they were soaked in WD-40. I also didn't want grease/WD to shoot all over the place, so the rag worked well.
Air Cooled
Weekend updates: I finished packing the front left wheel bearings and installed the hub, so the front is now completely assembled, and using Red Line CV-2 synthetic grease! Some pics of this final clean up and install.
![]() ![]() ![]() ![]() ![]() ![]() Finally...time to get to the rear end...
Pretty! I needed some motivation after yesterday. I spent at lest four hours on those damn swing arm bushings. My 20 ton press finally killed the elephant tool on the last one but it came off. Probably the most horrible job you can do on a 911, and I think I've done them all. Damn spring plate covers were rusted to the bushings, what a treat!
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
Air Cooled
On to the rear end! First remove the half shaft and tap it out of the hub with a big hammer and drive. Then remove the lower shock mount, the hand brake line, the sway bar, the rear brake pads and dust shield, and then tab out the rear hub. Then into the spring plate, torsion bar and trailing arm.
Here is the progression, and the interesting problem I solved with removing a stuck torsion bar from the spring plate. And so it begins.. ![]() ![]() ![]() ![]() ![]() ![]() ![]() Parking/hand brake line: ![]() ![]()
Air Cooled
Sway bar next, then on to the spring plate
![]() ![]() Next, tap the hub out: ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Air Cooled
Luckily, and after reading so many similar statements, I went with new ER spring plates and will be installing Poly Bronze out back. And yeah...I had a treat with the right side torsion bar being stuck to the spring plate. I can't wait to pull the bearings on the trailing arm.... Are we crazy? Yes. Is the job tough? Yes. Will we say things during the project that should never be heard by woman or child? Yes. Will we have have incredible machines when done and be satisfied with our effort? Hell yes!
French Import
Ahhhh, the infamous rear wheel bearing...
This tool helped me removing the half of the bearing on the trailing arm ![]() and I had to use a dremel to cut out the other half stuck on the hub axle, same as yours.
Zippy, like everything else my drive flanges are rusted in place so I can't yet get to the bearing. So to avoid any damage I'm going to find a machinist to have a look at them. The picture of Craig tapping his out from the rear with ease is making me mental.
Air Cooled
On to the spring plate and torsion bar removal. This was tricky, as the torsion bar was stuck to the spring plate. I drilled a hole in the end cap, and then screwed a coarse thread hex head screw...and luckily it pushed the torsion bar out of the spring plate! Got lucky with that one!
The pics: ![]() ![]() ![]() ![]() ![]() Oooh, great.. ![]() ![]() ![]()
Air Cooled
OR, "I got it out with 'Ease'"
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat" - - '99 Honda VFR800Fi, '98 Honda SuperHawk '88 Honda Hawk GT, '77 Honda CB750K Cafe '69 Honda CL350 Last edited by Craig_D; 02-18-2013 at 08:23 AM.. |
Air Cooled
Next up, trailing arm:
![]() ![]() ![]() ![]() I'm going to finish up my coffee, and head back out to the garage. It's nice to have the day off so I can focus on the left side.
If it was the rubber bushings on the spring arm, I have done 4 fairly recently and it was actually easy. I just took a wood saw, cut around the circumference of the rubber (it saws easy) and then just sliced it off using the same saw piece by piece. The small bits that were left I just took a wire brush on my grinder and poof...down to clean metal. Dennis |
French Import
