Send a message via ICQ to Kurt B Send a message via Yahoo to Kurt B
Post left brake light doesn't work when lights on
otherwise it works. I know it's odd, and I can track it down eventually, but as per usual, I figured I'd post it on the off chance there's a cause that won't require X hours I'll spend trying to track this down.
Kurt B
1984 Carrera Cabriolet
911 Page
carrera_cabriolet@yahoo.com
Old 08-17-2001, 02:29 PM
Post
Start with a new bulb. Clean the socket and the two contacts. Now clean the ground. It's the brown wire.
Tyson Schmidt
72 911 Cabriolet
92 C-2 Cabriolet
Old 08-17-2001, 11:28 PM
Not Quite Banned
Thomas Owen's Avatar
Post
Kurt,
Make sure your tail light bulb is not being lit during braking, and that the correct lamps do come on for tail lights and brake lights. If it looks ok, then I agree with Tyson, probably a corroded contact or bad ground.
I had some problems in my harness from a melted 3rd brake light wire that caused some real headaches....
Good luck,
Tom
Old 08-18-2001, 04:51 AM
