Unhappy I need help please.
Hello everyone,
I need help with an electrical problem. Two years ago I bought a 1970 911T. This was a project car so a lot of parts were removed and put in boxes. After spending about 20,000 US dollars, I am almost done but I can not figure out some electrical problems.
The fuse boxes were changed to generic standard fuse boxes and I don't know if all the cables are plugged in the wright order. The hazard switch was removed and I don't know how to plug it back...there is a lot of wires plugged in this switch. My mechanic is usualy very good in electrical problems but he is just about to do a burn out with the german electric configuration.
1)
I need the fuse box connection diagram in color.
2)
I need to know the wiring sequence on the hazard switch.
3)
Where can I get a wiring diagram in color for a 1970 911T.
Your help is greatly appreciated, I want to drive my car...please email me with any idea or guideline.
Paul - Montreal
*** porsche.911@videotron.ca ***
Old 08-15-2001, 08:00 PM
jabb's Avatar
Cool
This site has the Diagrams in color here is the link....
http://www.pelicanparts.com/911/911_Parts/Electrical/911_electrical_1973_CIS_Part1.jpg
Good Luck
  • Joe A.
  • 84 911 Targa
  • 75 914/6 3.0
Old 08-15-2001, 08:08 PM
Early_S_Man's Avatar
Paul,
Actually, the wiring color code, terminal designations, and device number (33) for the switch are identical for the 1970, 1971, and 1973 schematic diagrams are all identical, so you can print the '73 diagram referred to above, or the '71 diagram and its' key list to the device numbers:
http://www.pelicanparts.com/911/911_Parts/Electrical/911_electrical_1971_Part-1.jpg
http://www.pelicanparts.com/911/911_Parts/Electrical/911_electrical_1971_legend-1.jpg
Good luck!
Warren Hall
1973 911S Targa
1992 Dodge Dakota 5.2 4X4 parts hauler
[This message has been edited by Early_S_Man (edited 08-15-2001).]
Old 08-15-2001, 08:44 PM
Post
you really should bite the bullet and put the original fuse holders back in the car. they're readily available. if you can find another car to look at, you can draw up a diaghram of wire colors and where they go.
Old 08-16-2001, 08:19 AM
Senior Member
Post
Hello
The hazard switch has a suiting connector and all the little numbers refer to the color codes. All very simple and straight forward. theconnector is also keyed and allowing only one position. Just make sure you have the correct year switch.
Grüsse
Old 08-16-2001, 06:17 PM
Senior Member
Post
Paul,
Agree with the others... you need the orginal fuse box in the car. If you do not, each and every time you have ANY electrical problem with the car, its an experimental project for the mechanic. If you are not at home or your "normal" mechanic is not there to work on it, you then get to pay for someone new to learn all about it!
As well, it will lower the value of the car to ANY person who knows Porsches.
I am going out to a place today for some work on my car. They have an older coupe in the back that they are stripping parts off of and then crushing. They have GIVEN me the wiring harness and if there is a fuse box in the car I will get it for you... my cost is a Labatts Blue or two the next time I am in Montreal!
Joe
Old 08-17-2001, 05:02 AM
Senior Member
Post
Paul,
Back home now and have the wiring harness. It does have the metal brace where the fuse blocks mount. The fuse blocks themselves are already gone but the guys at the shop told me that they are not expensive.
If you want this part, where the relays and fuse blocks bolt onto the body, pls let me know.
JoeA
Old 08-17-2001, 06:37 PM
Senior Member
Doug Zielke's Avatar
Post
Just curious...
When did (if ever) Porsche get rid of these phoney fuses and cheesy holders?
You guys with the 964's and 993's...do you still have these crappy fuses in your "modern" cars?
I spent a whole afternoon cleaning every single flimsy brass contact in the front and rear fuse panels, and replaced all the fuses with new (crappy-style) ones. It made a huge difference in what finally worked properly in my car.
I could forgive these parts in a 50's car, but they should have been long gone by the 80's.
'81 SC Coupe (aka: "Blue Bomber")
Canada West Region PCA
The Blue Bomber's Website
Old 08-17-2001, 06:59 PM
Post
Did you know they used the same type on the titanic!!
Old 08-17-2001, 07:04 PM
Senior Member
Post
Doug,
Have done this for years as well. Was at Zims on Friday and they told me that the new fuse holders (old style) are not expensive and instead of doing this game every couple of years I am thinking of just replacing mine when they start acting up again.
Joe
Old 08-18-2001, 05:35 AM
