-   -   I am in a bind - any direction is really appreciated - interior issue (http://forums.pelicanparts.com/porsche-911-technical-forum/726854-i-am-bind-any-direction-really-appreciated-interior-issue.html)
Flat6pac 01-03-2013 06:17 PM
Any of the 85 and later seats sit higher in the early cars through 84.
Bruce
maui44 01-03-2013 06:24 PM
If the seat is lower in the back all the way you may want to consider changing them out to the proper year seat (auto or manual).
Reifle 01-03-2013 08:46 PM
I have a set identical to the ones in my car... Let me know. (Blue and in great shape - no photos at this time)
Rot 911 01-04-2013 05:38 AM
Bruce
No, this is only true for the '85 cars. In '86 they went back to the lower seat rails.
JTL 01-04-2013 06:42 AM
My car has manual sport seats and at 6'5" I fit just fine; a targa provides a little bit more headroom. During DE/Auto the top of my helmet does make slight contact with the inside of the roof but is still ok.
speednme1 01-04-2013 07:54 AM
I'm 6'2" as well. I just removed my seats and drilled new holes onto the metal seat rails(on the car). Gave me about 1-2 inches of seat travel. Very easily done and without harming the integrity of the car.
OttawaDave 01-04-2013 08:26 AM
Sorry for the brief hijack, but this brings back a question I asked a few years back, though the answers weren't entirely clear.
I have an 85, and though I'm not quite 6 feet tall, I have clearance issues with a helmet, and feel like I'm sitting way too high for regular street driving as well. My question from back then was: What was unique about 1985? The seat rails were raised, but there was also a new seat design introduced that year. All the SC's and Carreras from MY1984 had the previous seat design. So is it a combination of new seat and raised rails, or was it that the new seat installed higher on the SC-spec rails, which neccesitated modification for the 1986MY? My reason for asking is that I'm not keen about cutting down the rails, but wonder if I get my hands on a set of SC-era sport seats, would they provide me with the same head-room that I'd have in an SC, for example?
Scott S 01-04-2013 08:31 AM
Speednme1 -
Can you post or email me a step by step? 2" would absolutely solve my problem.
Thanks a million -
Scott S
Laneco 01-04-2013 10:27 AM
Originally Posted by snbush67 (Post 7186944)
married?.... let your wife drive.
Worked GREAT for us - hahahaa!!!!! :D
We have a 1980 that Steve put the same seats into (993). Absolutely no way he could fit in the car properly. He wound up making custom mounts to lower the seat. Literally cut out the stock ones and welded new ones to the car. I can barely see out of the car now when I drive it, but HE fits perfectly!
If I were in your shoes, I would FIRST try dropping that seat down as it is looks to be in the raised position. If that doesn't work, then swap them out for other seats. Yours are in great shape, you should do fine on a swap-out.
Enjoy the car!
angela
kinein 01-04-2013 10:56 AM
I am 6' 5", i took out the center console on my 86. i have sparco milano seats an with the bracket it basically sits on the floor. Next step is to get a smaller diameter wheel.
nameisbauer 01-04-2013 11:10 AM
Those same Recaros are for sale in the classifieds section here if still interested.
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/663676-early-recaros-pair-socal.html
I do agree, since the rear switch is non op, you could just not be all the way down.
If you don't care about sliding front and back you could delete the silders and mount directly to the rails?
Rot 911 01-04-2013 11:23 AM
I have no idea why they raised the seat rails in 1885. Maybe they thought they needed to with the new style seat. In any event they dropped the rails back down in 1986. For tall guys, I think the best option would be to find a set of 1978-1984 sport seats.
pitsqrd 01-04-2013 11:42 AM
I just read this after posting my idea about seat lowering brackets for my SC. I am about 6'3 and just barely fit in my car with the original SC sport seats but will not fit with my helmet on unless I recline the seats back in a less optimized driving position.
I have decided to cut my original seat mounting brackets and somehow put in custom lowering brackets. My post is asking about an idea to get past the concern of welding on the tunnel where the fuel lines are. Perhaps it will help you with seat set up.
To continue with optimized fit, I also put in a WEVO extended shifter and a Momo MOD 88 with flattened bottom to give some clearance for my knees. This set up with existing SC seat provides a good driving position but again will not allow me to wear a helmet for DE or AX, so the seat position will need to be lowered.
Hope this helps you.
GaryR 01-04-2013 12:11 PM
Shorter people had a hard time seeing over the horses... :D
speednme1 01-04-2013 01:37 PM
Originally Posted by Scott Schroeder (Post 7188345)
Speednme1 -
Thanks a million -
Scott S
Scott I sent you an email that I hope will help.
MysticLlama 01-04-2013 02:47 PM
Check underneath just in case there are factory spacer rails that the seats were mounted to. I've seen them on more than one Carrera.
Amochosto 01-04-2013 04:36 PM
Originally Posted by banda (Post 7187089)
First off that looks like a really nice 911 and I would love to see pics of the whole car.
Regarding your seat issue, you might be able to fix the issue by changing or modifying the seat mounts. Seems it might me cheaper and easier than changing the seats.
I have a set of aftermarket seat mounts that are adjustable and sit lower than the stock mounts. I can dig them up and send you pics. Let me know.
You might also check for posts on lowering seat mounts, I am sure it's been done before for tall drivers.
Bob
I am very interested in more info on this. I am 6'4"and am rubbing against the roofliner, any space increase is useful.
