Scott R's Avatar
Is this a Porsche part?
I can't believe that after a decade I'm still finding odd pieces in my car. These were in the bottom of the glove box under the manuals. Are they are factory part? Or just garbage?
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 01-05-2013, 01:12 PM
Taking it apart is easy
Jerome74911S's Avatar
It took you a decade to look in your glove box?
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 01-05-2013, 01:49 PM
Scott R's Avatar
I've been busy working on the engine and suspension.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 01-05-2013, 01:51 PM
912 Geek
My Guess: They fit under the door handles to protect the paint from scratches. Probably not a factory part.
Old 01-05-2013, 02:31 PM
crustychief's Avatar
That is exactly what they are, someone will buy them if you post them up. I sold a pair last year. They are not made anymore.
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 01-05-2013, 03:08 PM
Scott R's Avatar
WOW, thanks! That's exactly where they go! It appears that you remove or loosen the door handle, then remove the adhesive strip on the back on install. I can't see myself removing the door handles to install these so I suppose I'll put them in my parts box.
Thanks!
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 01-05-2013, 03:22 PM
AutoBahned
RWebb's Avatar
just put them in your glove box...
Old 01-05-2013, 04:03 PM
Scott R's Avatar
lol, I did, good guess.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 01-05-2013, 04:05 PM
