-   -   Xmas break projects, what did you do? (http://forums.pelicanparts.com/porsche-911-technical-forum/727376-xmas-break-projects-what-did-you-do.html)
SoCalSK8r 01-06-2013 03:06 PM
I was fortunate to have a long winter break so I did quite a bit of maintenance on the cars:
-new pads & rotors, fluid flush on my daily driver
On the Carrera:
-new brake hoses front and rear, added speed bleeders
-brake flush
-pedal cluster rebuild
-new clutch spring
-adjust clutch
-detail wheel wells and clean wheels (while I had all wheels off)
-wash car
I didn't get around to replacing the shift coupler.
Oh ya, and I did get quite a few hours out in the canyons....,:D
RDM 01-07-2013 06:51 AM
Let's see... a new (rebuilt) alternator installation, chain tensioner update, fuel injection investigation, and investigating my centrifugal advance. Christmas was good to me this year.
redstrosekNic 01-07-2013 07:01 AM
New Bosch foglights for the 924
Misc electrical issues rectified in the 924 (oil press. gauge, marker light, gauge lights)
Center console delete in 911
DIY leather shift boot for 911
Currently in the process of a pedal cluster rebuild, new clutch cable, and trying to sort the CIS throttle micro-switch.
spsfiend 01-07-2013 07:11 AM
Elephant Racing finned oil lines
bkreigsr 01-07-2013 08:13 AM
http://forums.pelicanparts.com/uploa...1357575154.jpg
yelcab1 01-07-2013 08:16 AM
painted 4 wheels
got new set of tires
polished all 4 cars
brake job on a Cayenne
saw movies
ate a bunch of food and drank a bunch of wines
JTL 01-07-2013 08:55 AM
1. Installed 66mm wheel studs
2. Sent Tach to NHWS
3. Started installing new front seats and still working on it
4. Letherique'd stock seats
timmy2 01-07-2013 09:07 AM
Drop engine, replace rockers and shafts with rsr seals, install Bitz EFI and tune car, replace rear shocks, sway bar bushings and links. Engine back in and driving.
2 days off and weekends for my break....
KTL 01-07-2013 09:09 AM
Removed all glass, interior, electrical for redesign of interior (racecar). Will be installing flush mount side & rear lexan, repainting interior white after reinforcing safety cage & suspension and rewiring the entire car with new custom wiring.
bigel 01-07-2013 11:09 AM
Well, I...
Applied 20" of blown-in insulation in my under-insulated attic space
re-routed my rain downspout across the back of the house to a common discharge
Installed four, six-panel entry doors in the second floor of the house (oh and trimmed out those doors as well)
Installed a new Grohe shower arm and shower head and re-caulked the master bath
and partied my fanny off.
Who has time to work on the 911... :(
70SC 01-07-2013 11:10 AM
headers
I did headers & some supertraps just for fun :D & lost 26 lbs & gained some good mid- top end power too :cool: Need to lower the rear again [/img]
http://forums.pelicanparts.com/uploa...1357585485.jpghttp://forums.pelicanparts.com/uploa...1357585585.jpg
fitchn 01-07-2013 11:48 AM
1) Replaced fuse box with ATO style block from Fred Cook
2) Replaced instrument cluster backlights with LEDs from Etarga
3) Euro style H4's installed with 80/100W bulbs
4) Removed stock leather driver's seat and removed the leather to sew a seam that was coming apart.
5) Reinstalled front trunk heater system after 3 years (!) of sorting out a small electrical meltdown.
6) Lubed and aligned window regulators to fix slow window issue on both sides.
7) Then went for a drive along the front range of the rockies.
It was a good Xmas break!
weseeeee 01-07-2013 01:10 PM
Painted a flat deck lid and replaced my whaletail/rear deck lid. I also went for a number of coastal drives covering approx 700 miles:)
tobluforu 01-07-2013 01:23 PM
Stayed warm, bought a new steering wheel and put it in the closet. My car is in deep hibernation.
5:04 01-07-2013 01:34 PM
Christmas day I installed some Rebel Racing Coilovers
http://25.media.tumblr.com/b19002818...zs7zo1_500.jpg
Then New Years day I parked it in the garage and pulled the front control arms off to have them worked on.
http://25.media.tumblr.com/be0534ab4...zs7zo1_500.jpg
Josh D 01-07-2013 01:50 PM
Engine/tranny drop for clean, reseal, pinion bearing replacement and clutch. Also doing CV boots and grease repack. I'm not done yet.:(
http://i906.photobucket.com/albums/a.../engineout.jpg
http://i906.photobucket.com/albums/a...rannyparts.jpg
http://i906.photobucket.com/albums/a.../engine1-1.jpg
911M491 01-07-2013 04:33 PM
Oil lines; hard and soft, Aux oil cooler fan switch http://forums.pelicanparts.com/porsche-911-technical-forum/727595-oil-lines-restoration.html#post7194813
Fuchs restoration http://forums.pelicanparts.com/porsche-911-technical-forum/727568-fuchs-restoration.html
jhelgesen 01-07-2013 05:54 PM
http://forums.pelicanparts.com/uploa...1357610014.jpg
Craig_D 01-07-2013 06:04 PM
Put my '78 SC up on jacks and pulled the front suspension off for a complete Elephant Racing rebuild, thread here.
It was bloody cold in the garage so I didn't get as much done as I wanted. But I progress a little bit each night. I found some nightmare problems that I solved with luck, so a new control arm, new spindle spacers and new bearings.
Even with the nightmare stuff, I still love it! :)
http://forums.pelicanparts.com/uploa...1357610439.jpg
http://forums.pelicanparts.com/uploa...1357610498.jpg
http://forums.pelicanparts.com/uploa...1357610542.jpg
al lkosmal 01-07-2013 06:07 PM
Got this running
EFI MFI Gasser 001 - YouTube
And got this running
912 home 007 - YouTube
regards,
Al
