krshome's Avatar
What fuse goes to the coil
I have three different schematics for my 1988 Carrera but non are the same???? Does anyone know what fuse is to the coil, what amp fuse it is and the color wire used for the coil wire? My info all say terminal #15 what is fuse #8 on the sticker a 16 amp fuse. all my schematics say the wire should be black. Nothing matches up. Any help here would be greatly appreciated.
Old 01-18-2013, 10:36 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Coil Fuse.
Here you go:
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 01-18-2013, 11:03 AM
Fuse panel.
1986 911 Targa.
Only in L.A.:
Old 01-18-2013, 11:08 AM
dshepp806's Avatar
What are your other "two"?
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 01-18-2013, 11:13 AM
krshome's Avatar
Thank you 86 911 Targa. You wouldn't by chance know the color of that wire. The red fuse to the right of the two blue is #8, the fuse that should have the black wire for the coil.
Old 01-18-2013, 02:52 PM
HOPE THIS HELPS:
As you can see, per the fuse panel jpg I sent you,
there are two black wires on the output of fuse #8 on our '86.
Pull one, and see if it's the right one.
Good luck,
Gerry
1986 911 Targa.
Only in L.A.:
Old 01-18-2013, 03:11 PM
krshome's Avatar
Thanks 86
Old 01-18-2013, 03:34 PM
