Rear suspension arms, bannana
Anyone know someone who can straighten the rear arms?
Senior Advisor
they should be bent!
08 Cayenne Turbo |
Grand Am/IMSA Data Guy
Much easier to replace with used ones, they are pretty cheap
Jerry Austin AIM Data Products Dealer 84 911 3.6 track car - Sold Morris Minor Van with S2000 running gear http://austinmotorsportsllc.com/ |
answers
Can either of you answer the question or not?
Racer
PMB Performance
Answer - No.
Question - When they are so inexpensive in the used market; why?
Eric Shea - PMB Performance 855-STOP-101 We Restore Vintage Calipers www.pmbperformance.com |
Porsche has a special tool to check the correct alignment of trailing arms. I have never seen anyone who has one, it is just shown in the early manuals. The banana arms have complex geometry. They need to manage both camber and toe, so straightening really means bending in multiple planes at the same time. If you are talking about 911 arms, used ones are available for $150 or so. If it is for a 930, more expensive. I have one 911 arm (don't remember if it is L or R) and a pair of 930 arms if you want to consider buying a replacement.
Ayo Irpin, Ukraine!
What car?
What year? What material type? Europe? US? Where exactly are you? Do you have a budget? What's your expectation for the quality of the work? Daily driver, repair/flip, concourse restoration? How can anyone give you a reasonable answer when your question was deficient? I'm sure I could straighten it. I have a pretty big sledge at home.
Harmlessly passing gas in the grassland away; Only dimly aware of a certain smell in the air |
My guess is that its for real RSR parts. Gunzel tends to populate those threads.
To the topic, you might want to check with Chris on the early S board. He pulled up stakes here after being run off (after sharing some really amazing metalurgy info) for being called stupid. Anyways, he has cut down LWB to SWB and has a jig. Has told me that alot of the SWB 'handeling issues' (read ballast weights) are really flexing in the early banannas. I think Im recalling that right. t
1967 912 with centerlocks… 10 years and still in pieces! |
How about these guys?
Aase Sales — 911 RSR Trailing Arms with Hubs and New bearings If it is the company I read about, they reproduce but also rework RS/RSR arms. (I'm not positive but I think it was the company featured in a british mag recently). Then again, it might have been this company, I can't be sure. http://www.twinsparkracing.com/products.html
73 RSR replica (soon for sale) SOLD - 928 5 speed with phone dials and Pasha seats SOLD - 914 wide body hot rod My 73RSR build http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html Last edited by wayner; 01-08-2013 at 11:26 AM.. |
Jerry
Right on all counts. I have the special tool to check the arms. If you ever need one checked I will be glad to check it for you. My arm is for my 73 RSR so buying a replacement is expensive so I thought someone might be set up to correct bent arms. Thanks for the reply. Mike Curnow Quote:
Suspension Arm
Wayner
A great suggestion, I didn't realize Aase was making new ones. Since they make new ones maybe they can straighten an old one? I will contact them. Thanks Mike Last edited by Gunzel; 01-08-2013 at 10:01 PM.. |
Rear Banana
You are correct, its an RSR Banana. Chris may be a possibility, I think he was threatening to make arms at one point. I never heard if he got into it or not. I will check it out. Thanks. Mike Last edited by Gunzel; 01-08-2013 at 10:00 PM.. |
Mike,
Perhaps you could try a larger specialty machine shop ( aerospace, aircraft, military inclined) that has the skill and experience press "bumping" of expensive menbers into dimensional tolerance. NASA uses this when analysis proves it. Don PS: How did you make out with that RSR crankshaft I sold you many years ago? |
