-   -   Rebuild Calipers - DIY? or Buy Rebuilt? (http://forums.pelicanparts.com/porsche-911-technical-forum/728082-rebuild-calipers-diy-buy-rebuilt.html)
frankc 06-20-2015 07:16 AM
Hi Vern,
Which brand of rotors are those? I like the finish/plating on them.
Eric_Shea 06-20-2015 09:14 AM
Originally Posted by 911euro (Post 8675360)
Quick embarrassing question: the rear caliper has 2 19'' bolts to the hub, my question is: there is very little space to put in big wrench to remove it. Is there a trick or a special wrench to remove this lower bolt? I just rebuilt the fronts and now I need to rebuild the rears because after releasing the hand brakes, the brake light on the dashboard is still lid up and it makes squeaky noise. I took a peek at the pistons earlier, they look to be rusted on the exposed portion.
Thx
On the rear of the 911 the handbrake cable has a plastic attachment to the control arm. Take a 10 mm wrench and remove that and then put your socket through the hole in the control arm to reach the lower bolt on the caliper. ;)
rokemester 06-20-2015 03:55 PM
Never feel embarrassed to ask a question in this forum. I had a tough time removing those nuts as well! I actually trapped a socket wrench trying to remove them and had to leave the scene to gather myself and figure out what to do. As usual Eric has a great tip to avoid this stick point.
86 911 Targa 06-20-2015 05:05 PM
Calipers.
When I did the brakes/rotors on our '86, I sent the calipers to a local machine shop
who broke them down & rebuilt them for about $85 each.
I though it was money well spent.
Gerry
frankc 06-21-2015 09:23 PM
Hi Eric,
As I'm sure you know, the plastic piece that you mention is only on the steel trailing arms (that I have seen). The aluminum arms have a hole cast in the arm itself for capturing the handbrake cable. I only mention this because the OP stated he had an 1985 Carrera (aluminum TA).
Eric_Shea 06-22-2015 06:21 AM
Gerry
It is, if they replated them.
99.9% of caliper failures are cause by rust... "inside the bore". After roughly 20-30 years, the zinc plating wears off the inside of the bore and, brake fluid being hygroscopic, it attracts water which likes to gather by the rubber seals, of course, right where the wears marks are. This causes rust and causes your pistons to stick.
This is what we always advise people to "NEVER" hone the bores and "ALWAYS" replate the calipers using the factory zinc (not cad). ;)
Otherwise... They'll be sticking again in two years.
Tidybuoy 06-22-2015 10:22 PM
Originally Posted by frankc (Post 8675786)
Hi Vern,
Those are pre-painted Zimmerman rotors. I believe it's about $10 more to get them pre painted but I think it was worth it - no rust. Purchased thru Pelican.
cabmandone 06-23-2015 05:03 AM
I guess this puts me "on the clock"
