PhD on Pending Projects
wachuko's Avatar
Send a message via AIM to wachuko Send a message via Yahoo to wachuko
Question Hole in CIS??
I was installing everything back for the engine of the RS project. I can figure out if there is something wrong. Is this hole supposed to be there??
Close up
Need to figure it out so that I can finalize the work on the engine. Thank you!
Drive safe!
1967 - Porsche 912
1981 - Porsche 911 SC
1991 - Porsche 911 C4 Wide-body Cabriolet
Old 01-12-2013, 08:28 PM
wachuko's Avatar
Ok, so it is the hole used to put an allen down there to adjust the idle. Idle mixture screw location.
Question is...Do I need to plug it?? And if so, with what??
Drive safe!
1967 - Porsche 912
Old 01-12-2013, 08:39 PM
Chief Head Scratcher
kerthunk's Avatar
Yup, that is the hole for adjusting the mixture. Porsche left them wide open till somewhere in the early 1980s. After that they covered them, but I believe it was to keep ordinary folks from screwing up their mixture and causing emissions issues.
Yours actually looks like it was a plugged one that was drilled out. The holes are much cleaner on earlier ones.
John Morris
'79 911SC
Old 01-12-2013, 08:56 PM
Designer King
Paulporsche's Avatar
You don't HAVE to plug it, but I would advise doing so to keep dirt, pieces from the sound insulation blanket, etc out of the head of the mixture screw. Some use a golf tee. I used a piece of brass tubing and I wrapped the bottom end w/ some self vulcanizing rubber tape to give it some grip on the edge of the opening. Just make sure the plug doesn't protrude too far down or it could impede the movement of the sensor plate.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 01-13-2013, 11:22 AM
Functionista
manbridge 74's Avatar
It originally had a metal rod with a loop on one end and conical rubber piece on the other.
You can sometimes find these on other CIS cars at the junkyard. Not sure if it's still available or would even help you out as your hole is irregular.
Old 01-13-2013, 11:37 AM
Plastic knitting needle cut to length, works on mine.
1978 911SC
Old 01-13-2013, 04:22 PM
I've seen golf tees plugging the hole
Old 01-14-2013, 06:45 PM
wachuko's Avatar
Cool! Thank you all for your suggestions!
Drive safe!
1967 - Porsche 912
Old 01-14-2013, 06:48 PM
enzo1's Avatar
76' 911s Signature Edition
Old 01-14-2013, 07:30 PM
