transmission mount bolt threads
Hello-On Sunday I took the engine out of my 76. Next will be to clean up some hack wiring in the engine bay and get it ready for the 3.2 install. When I removed the transmission bolts-both turned out to be non-standard slightly longer versions without the pointed tip. One has coarse thread, the other the original fine thread. When I screwed the bolts back in-they fit loosely and it feels like there are not many threads left in either socket. So-what to do?
1. I could clean the sockets and use a generous amount of loctite at reinstallation.
2. Drill out the threads and tap a larger thread size. How much metal depth is available in the socket?
3. Another method?
Thanks in advance for your answers.
Old 01-16-2013, 06:13 AM
schumicat's Avatar
I have seen people report helicoil and similar inserts work well here. it sounds like someone already may have tried that given the different threads. I wouldn't try #1. loctite keeps a bolt from backing out due to vibration, etc., but I don't think it will do much if the bolt fits loosely in the first place.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 01-16-2013, 06:40 AM
I stripped one a while back, learned the hard way to loosen the mounts on the transmission mount, get the bolt started and then tighten everything up.
I helicoiled the hole, it was a PITA but there have been no problems to date (2 years).
Dennis
Old 01-16-2013, 06:59 AM
If you were going to use a helicoil-dosen't that require drilling out a larger hole and screwing in the coil? If so wouldn't it be better just to tap a larger thread?
Old 01-16-2013, 04:15 PM
you end up with a larger hole, but a helicoil reduces the size to the previous hole size. This is so you can continue using the stock bolt, with the self centering tip. If you do not mind a larger bolt, then you can tap a larger thread size hole.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 01-16-2013, 04:32 PM
dshepp806's Avatar
Time-Sert!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 01-16-2013, 05:08 PM
Send a message via Skype™ to Porboynz
Time cert or heli coil, all good, common issue. Once repaired make sure you have original bolts and ensure they do not bottom out. If you use non original fasteners adjust with slightly thicker washer or shorten non original bolts but make sure they do not bottom out because that will destroy the thread.
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 01-16-2013, 09:46 PM
Time sert or helicoil it is then. Does anyone have a loose trans bolt that they could confirm that the thread is M12x1.5? thanks again.
Old 01-17-2013, 10:58 AM
Canyon Runner
70SC's Avatar
Porsche Crest 12 x 1.5
you are correct sir M12 x1.5
Old 01-17-2013, 11:01 AM
