Factory extended hub steering wheel
Hi All -
I want to move the sterring wheel back away from the dash. After some searching, I thought the factory extended hub three spoke wheel would be perfect (wanted to keep things looking stock). I even through a WTB add up a few minutes ago. However, in doing some additional research, I have found two references to the extended hub wheel requiring an extended steering shaft as well. Will an extended wheel simply bolt on or not? My car is a '77 S. Thanks a million - Scott S |
shaft is not needed on my 86 wheel.. the extended hub just that, extend. It is held on the wheel by 3 bolts.
Scott, I will likely be removing the extended hub wheel in my car in a couple of weeks or so. PM me...
The extension is all in the hub and a longer shaft is not needed.
JR |
| All times are GMT -8. The time now is 10:36 AM. |
