Battery drain
I put a new fully charged battery in my car and drove it once and the next day the battery was flat. I recharged the battery.Next I disconnected the ground cable from the battery post and l measured across them with an ammeter I had 9 amps !! As I read in other posts I started to remove fuses while watching the meter the last oneI removed the 25A power window fuse was HOT after it was removed the reading was zero on the meter.
I have left the fuse out but not sure what to do next , Iam thinking it could be the passenger door switch , how can I proceed with the testing ??
Old 05-11-2013, 04:46 AM
Unplug the switch and look at the amp meter " set he meter on the
Highest amp setting first , it could also be a stuck relay so remove those also.
After you exhaust all fuses relays door switches trunk switches .
Also don't forget the little light over the motor if you have one. Like whale tails
Also do a search for diode , the one behind the batt dummy light
Last disconnect the alternator Guys will also jump in later the day
What car. What motor and any recent installs of anything .
Old 05-11-2013, 06:50 AM
The car is an 81 SC 3.0 ltr stock motor. I thought by pulling the fuse for the power windows which was very hot to touch that the drain circuit was found. Now I need to figure out why. The passenger side power window switch is intermittent in operation
Old 05-11-2013, 05:23 PM
Member 911 Anonymous
DRACO A5OG's Avatar
you have short on that switch, pull the switch and the wiring, check for a cut line, the regulator may have cut into ine of the lines.
'85 Carrera Targa
PCA/POC
Old 05-12-2013, 05:29 PM
theiceman's Avatar
at 9 amps im thinking you have a window motor trying to drive. see is any of them are hot and unplug it. sounds like the switch may be driving it
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 05-12-2013, 07:43 PM
I've seen the window switches fail to the point they are constantly trying to lower the window - I've had to replace them 2-3 times during the 20+ years I've had my 911. After the HVAC and the brake M/C pressure switches, this is the third worst design on our cars; they look cheap, they don't have a unified connector AND they fail.
Chuck.H
'89 TurboLookTarga, 352k miles
Old 05-13-2013, 05:36 AM
Cooper911SC's Avatar
If you replace the switch get the Genuine Porsche switch.
The OEM eqivalent switches are not well made.
Cooper
Old 05-13-2013, 06:21 AM
I appreciate all the feedback re this problem . Iam back out at work now for 2 weeks in the desert and will have to continue with this when I get back at the end of May...such is life on a 2 week rotational roster. I reckon it is the switch and will be onto it . It will be the second thing I do when I get home.
Thanks all.
Old 05-13-2013, 03:25 PM
