rnln's Avatar
oil hand pump.
Hi,
the part I hate the most about changing oil is to pour old oil from the bucket to empty botttles and take them to autozone or walmart. So, I am thinking of getting a cheap hand pump. Has anyone ever use this type of hand pump?
Fat butt 911, 1987
Old 01-15-2013, 10:27 AM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
I have used one of those transfer siphons for gas. Pretty small ID on the hose, I think you will be quite a long time tranferring the 11 or so liters/quarts of oil.
Old 01-15-2013, 10:33 AM
I use a high-capacity drain pan and a 5 gallon jug intended for Kerosene. The pan has a spout that goes right into the kerosene jug for a fast, (generally) mess-free transfer. Then take the jug to the oil recycler. It's worked well for ~12 years
'90C4
Old 01-15-2013, 10:44 AM
Friend of Warren
That's what I do.
Kurt V
Old 01-15-2013, 10:57 AM
redstrosekNic's Avatar
I use a funnel to pour oil into 5 gallon buckets that I get from work. That pump will take forever. Try this...
Multi-Use Transfer Pump
Dustin
Old 01-15-2013, 11:34 AM
I have tried that pump too, and it is only worth $8. I too use a 5 gal can. An old Kerosene can I have had for 30 years, back when I used Kerosene to heat my garage. Today, I save it for my son who has a marvelous furnace in his garage that burns old motor oil, (like some car service garages have). All his buddies save their oil for him, and I do too. The job I hate is changing gear oil in the transaxle. Not the draining, but the refill. Any of you have a solution for that?
I don't always talk to liberal arts grads, but when I do, I tell them Big Mac and small fries!
1974 911 RUF Clone ('85 3.2; '86 915)
1974 914 ('87 3.2L & 915 transaxle)
2005 Boxster (Base car) Guards Red.
Old 01-15-2013, 01:31 PM
rnln's Avatar
Burn old oil in the garage? How about the smell?
For filling oil, I use similar hand pump Dustin posted above. It is ok for that purpose.
Fat butt 911, 1987
Old 01-15-2013, 01:45 PM
You would not believe, the 'furnace' has a chimney, and it does not smell. Makes a hell of a lot of heat though. His garage is a semi insulated metal pole barn.
Old 01-15-2013, 02:00 PM
peppy's Avatar
I use one of trhese.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
1982 Chevette Diesel SOLD
Old 01-15-2013, 05:45 PM
Member 911 Anonymous
DRACO A5OG's Avatar
oh rnln, that thing is a pos, I have one, I used it to change the power steering fluid on the Lexus, what a mess.
'85 Carrera Targa
PCA/POC
Old 01-15-2013, 08:50 PM
rnln's Avatar
remember how I need help pouring oil from my bucket to the quart bottle? I don't want to live with it. I have to come up with something.
Maybe I am going to build this into a metal lid.
Fat butt 911, 1987
Old 01-15-2013, 10:42 PM
Peppy, where did you get that and what is it made for? Dale
Old 01-16-2013, 03:44 AM
tazzieman's Avatar
For all my cars I use a stout garden pump spray bottle + tubing , takes a couple of refills but gives you time to go inside and make a cuppa etc. Painless.
'81 924 , '85 944 , '78 911SC , '82 928 5.0L
"They run best being run close to the ‘limit’ and done so regularly" - Grady
Old 01-16-2013, 03:49 AM
Banned
I used a hand pump sourced from our host. The real key is to get a big pan of water really hot on the stove. Then take the pot to the garage and put your trans oil bottles in it, and walk away for 10 minutes. After that, the hand pumping takes very little time.
Old 01-16-2013, 08:31 AM
peppy's Avatar
[QUOTE=daleflesburg;7211217]Peppy, where did you get that and what is it made for? Dale[/QUOTEe
I got mine from Griot's Garage about 15 years ago. I use it for gear oil and refilling transmissions. I also used it to suck ATF out of a Ford F150 that a friend overfilled.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
Old 01-16-2013, 09:22 AM
i save gallon windshield washer fluid bottles and pour from my pan directly into the bottles (using a funnel) -- only takes 2.5 bottles per oil change
fwiw
Old 01-16-2013, 01:00 PM
Also the new 5+ quart plastic bottles that they are selling oil in at the flaps work well.
Old 01-16-2013, 01:05 PM
rnln's Avatar
this is what I am doing but I want to pump now instead of pouring.
fwiw
Fat butt 911, 1987
Old 01-16-2013, 02:01 PM
Barrpete's Avatar
For motor oil these work great:
Drill Pump - Overton's
I use it to pump the oil out my V8 boat engine since there's no way to drain it from the oil pan. Just hook it up to a standard drill. For your application make sure its a variable speed drill so you can pump slowly enough that you don't overfill your bottle.
1986 Carrera Coupe
1999 Chevy Tahoe
1987 Chevy Blazer
1955 Chevy Apache 3100 Pickup
"A little knowledge is a dangerous thing"
Old 01-16-2013, 02:22 PM
