ignition switch X wires
1981 911 SC euro
The ignition switch X port is really two ports with an X between them. On the back of the ignition switch, one has a red/yellow wire and one has red/white. On the front, there are separate ports as well.
1) Does the red/yellow wire only go to the power windows? (This is what I found from the wiring diagrams on this web site but I want to be sure.)
2) Does the ignition switch junction join the two X ports electrically or should there be a separate power wire in for each X port?
Thanks.
Old 01-21-2013, 02:07 PM
Bump to see if I can get an answer. Thanks.
Old 01-23-2013, 02:21 PM
Tags
ignition switch , red/yellow
