-   -   help with removing heads! (http://forums.pelicanparts.com/porsche-911-technical-forum/73006-help-removing-heads.html)
jhugh 06-29-2002 02:55 PM
So I've had my engine out since last weekend, now I'm just doing some disassembly. I'm stuck now trying to pull off the heads. Is there any secret to getting the oil return tubes to let go? I've been pulling and rocking the heads - they're mighty loose except for those tubes - but they won't come. I'm worried that all my jiggling around is going to make metal flakes. Tips appreciated!
Thanks,
Superman 06-29-2002 04:16 PM
No special tips. Just pull hard.
yelcab1 06-29-2002 04:19 PM
The original factory tubes just press in and seal with Viton O rings. Just pull hard straight out.
Wayne 962 06-29-2002 05:48 PM
Crush the old tubes with vise-grips, and they will pull right out. I like to use new ones anyways...
-Wayne
Wayne 962 06-29-2002 05:49 PM
Or do this:
http://forums.pelicanparts.com/uploa...e-engine11.jpg
-Wayne
Mikko Kosonen 06-30-2002 03:58 AM
One thing also to add WD40 or some other "loosener" and then twist (or roll) the tubes with your hand. Then just pull them away.
